Hi,
Looking to get some additional input on repairing a color (colour...) classic Macintosh.
Here's the tests and procedures, in order, that I have done so far:
Pulled motherboard to check power supply functionality- OK
Washed motherboard and reinserted for a basic check- FAIL
Removed rear housing and checked A/B board for leaking caps- OK
Replaced motherboard caps and checked functionality- FAIL
Double checked replacement caps- OK (AFAIK...)
Tried the "remove and insert mobo" trick- FAIL
Checked for the continuity points between the ADB chip and external ADB pins / mobo edge connector- OK
Checked for continuity on the nearby via by the ADB clock- OK
Essentially, I checked all results Google pulled up on the color classic and related repair attempts that had been documented online. There was one here posted about a year ago, but that thread seems to have never been resolved and I'd rather not necro-post it.
I purchased this Mac to give a go at repairing a compact Mac by my own hands. I've fixed up ones in the past, but have always sent the soldering jobs to others. Seems I'm in a bit over my head now. The recapping went without a hitch, as far as I can tell. They're more or less flat, there's no shorts, no lifted pads, and polarity has been triple checked.
With the board removed, the power supply starts up well. No whining caps, no delays; sounds brand new.
If anyone has some experience in repairing these machines, I'd greatly appreciate it. I'd really hate to give up and just cheat my way to a functional machine with a replacement board.
Thanks in advance.
Thanks in advance.
