475/605 motherboard in 550
without the edge connector no.  I believe that is incorrect.  The 550 uses the same motherboard as the color classic II.
I suspect somewhere along the way someone has mixed up that the 575 and 475/605 boards (which are meant to be pretty much the same logically) are compatible physically, and they're not.
It'd be worth dropping a message to lowendmac and letting them know that's wrong.
The 550 can't take the 580 or 630 board because they use IDE instead of SCSI, correct? Or do those boards support SCSI as well as IDE?
they cannot take it.  They do support scsi still externally but not internally.  I am not sure if you could just put an ide drive in place of the scsi drive and change the board as I have not tried but i dont think the cables are the same.
