As far as I know, the IIvx is the first to use the case design. Along with the IIvi. I found an oddity I can not figure out. On one unit, I have vents on the top and side. On another, just on top. Also on the one with vents just on top, there is a secondary metal assembly that seems to be for air flow. Its not present on the top with vents on top and side.
What do your IIvx look like? Vents on one side or not? Metal sub-assembly inside? Was this a running change? Because the one with vents on one side and top are from a very, very early machine.
