I might be receiving a duo but I have no dock to do file transfers. any ideas
Whoops sorryWhy is this in the lounge?
Also, most docks are inexpensive. Unless you're going for ethernet docks or DuoDocks.
Agreed. And, again, you don't need any kind of dock to do it as Duos do have a built in serial port.No need to do any fiddling with a terminal if you have another Mac. Attach a printer cable to each Mac's serial port and set up AppleTalk over LocalTalk. Should Just Work.
Maybe in your opinion. You've entirely misinterpreted what I said. And like you said, you've no experience to base your remarks upon. You're networkcentric in your thinking, having grown up in an era of ubiquitous networking that's understandable, if not inevitable.Using a duo as a Target Disk mode boot device seems insanely inefficient and perhaps like a pretty(1) bad use of the hardware. You can get regular dedicated external hard disks for that task.
<snip>
(1) I admit that I have no Duo and can't imagine setting, say, my 180 or 1400 aside and basically saying "this is an external hard disk now!" It's a whole computer and it seems like it would be best used as one.
edit: get yourself a Dock and try setting the Duo up to act as a general purpose boot drive for testing HDD deprived acquisitions or for future sessions when transferring files and installing software across your collection. You can do it with most any PB from the second generation on, but using a 68030 Duo or PowerBook 100 is way cooler!
