Good evening all,
I obtained 2 Macintosh Portables this week, been working on it - got new battery fitted etc...
Since the language was Turkish (previous owner was Turkish)
I wanted to install fresh system on it, so I used System 7.1 Disk Tools to format the HDD - didn't realise I might have made a big mistake for it, some how formatting failed. I tried to format under System 6.0.4 - still failed.
Does that mean Ive destroyed the internal HDD? It was working perfectly before I formatted it.
What other options should I do - find another conner HDD - swap boards over, and put it in Macintosh ie. Classic/SE etc and try format it?
Or another formatting program should I use?
Would prefer to leave as original as much I can.
Cheers
AP
Cheers
AP
