I've got a Quadra 840av with broken SCSI bus - neither internal nor external SCSI devices can mount properly.
I want to install a NUBUS Jackhammer SCSI card that I hope to use for connecting drives.
If I understand correctly, in order to configure the Quadra so that it can boot from an HD connected through Jackhammer, I first need to configure the Quadra to boot from a RAM disk so that I can have System 7.x up and running, run the Jackhammer config software from floppy (which I have) and then instruct the Quadra to use the Jackhammer hard drive as the Startup Disk.
BUT the catch is: how can I set up a RAM disk on the Quadra if the only thing I can currently boot from is a floppy? What I mean is, having a System & Finder on the floppy doesn't leave enough room for the Memory and Startup Disk control panels that I need to set those things up.
Is there a workaround that I'm not thinking of?
