...or restart. It locks up right at the point where it would normally power down and just sits there.
If there are no drives connected to the Jackhammer it works normally.
If I swap out the Jackhammer for a Silicon Express IV, it works normally.
Apart from the shut down issue, everything about the Jackhammer seems to work normally.
As best I can remember (it's been a while) the Jackhammer worked normally in the last system I tried it in, which was a Quadra 800.
The drives I've tried (one scsi2sd v6 and a couple of quantum prodrives) are not formatted with the FWB utility, is it mandatory to do so with a Jackhammer? I don't recall having to do so in the past, but I might be mis-remembering...
There is no pram battery installed, might that affect the Jackhammer?
