Yep, all SEs have a 50 pin SCSI header on the mobo. I assume the Molex is also in the wiring. It'd actually be cheaper for Apple to leave it in by reducing the number of wiring harnesses to stock.
Nooo... SCSI2SD can be powered from the Termination. On the plus, you have to solder in a diode. and that diode is right next to the SCSI IC so its just an additional pin up the same ribbon.What would power it though? Doesn't it need a Molex?
I have to disagree with that statement. I personally love my Ethernet networking card in my SE FDHD. Allows me to push data directly to it from my MacBook Pro... There's not really anything useful to put in the PDS slot of an SE....
Make that a three. I also have one but I can't find the drivers\software anywhere (non-corrupted, anyway). If you watch ebay for a while they do pop up now and then fairly cheap.They're obtainable, at least two of us in this thread have them![]()
I'm pretty sure the one I have works in System 6, but it's been a couple years since I messed with it. For sure in 7.1.
What make/model is yours? I'll fire mine up and see what I have... who knows, maybe we have the same card.Make that a three. I also have one but I can't find the drivers\software anywhere (non-corrupted, anyway). If you watch ebay for a while they do pop up now and then fairly cheap.
