FriendlyNet Hub
ktkm
I’m looking for a new power adapter for a 5-port Asanté FriendlyNet Ethernet hub (since I bought it without one).
The hub states 5VDC but how many amps is the output?
I have tried 1A but can’t get a stable network going between my PowerBook G3 (Pismo) and Mac IIcx (MacCon+). (They sometimes show up in the Chooser).
The strange thing is, when I use port 5 for the Mac IIcx, next to the up-link port connected to my cbn router, I can connect to the Mac IIcx from the PowerBook, but when I try to connect from the Mac IIcx to the PowerBook the chooser crashes.
Help really appreciated!
BW,
Kristian
I don't have one of those to check, but can say that judging by the sheer size of hub adapters I've come across, you'll surely need more than a 1a adapter. You also can't have less than 5v, but you can have a bit more.
Check for bad caps on the Friendly Net hub's circuit board. I picked up a d-link 12 port 100bps hub a few years ago and it had a bunch of bad 10 uF radial caps on board.
A bit more? I have an adaptor with +12VDC 2,333A is that too much?
Do you think it could have something to do with incompatible power supply or just normal wear and tear?
