Mac virtual machine software for Mac guests.
Hi:
 I have a couple of Mac OS and PowerPC Linux distors I am not currently using. Is there a way I can run these are guest OSs(like you do with virtualisation on the PC)? Are PowerPC machines too slow for this?
If you're willing to run Linux as your host OS there are several options. (MoL, MoL+KVM, QEMU+KVM.) I don't know of any OS X based virtualizer for PPC.
Then I suspect you're out of luck. There's Sheepshaver if you want to count it, but of course it only runs old versions of MacOS.
You could also probably compile QEMU without KVM support to run a PowerPC "guest", but it'll use emulation instead of virtualization so it'll be monstrously slow.
AFAIK the PowerPC chips used in Macs don't include virtualization extensions similar to those in x86 chips that virtualization software like QEMU or KVM takes advantage of, so unless you use something like Mac-on-Linux on a Linux host (which appears to be a special case) you're limited to emulation. Use of virtual machines was just starting to take off as PPC was phased out.
That is *not* true. PowerPC doesn't need any special "virtualization extensions" because the PowerPC ISA has always been fully compliant with Popek and Goldberg virtualization requirements and doesn't need any "help", unlike i386. (Programs like VMware managed "virtualization" on x86 before AMD-V/Intel VT-x only via some pretty wasteful workarounds.) There are working virtual machine programs for PowerPC (such as the aforementioned MoL and KVM for Linux), there just don't happen to be any written for OS X because, let's face it, Mac users didn't really have much use for them. There are people running OS X and Linux guests on top of KVM on both Macs and oddball other PowerPC architectures (IE, Amiga X1000s), you just can't use OS X as the host.
It looks like some of these emulators also run on x86, if I wanted to experiment with these OS on a PC. (though emulation will never run the same as real hardware.)
KVM works under Linux on a PPC Mac? TIL.
It was news to me until fairly recently. It sort of makes me want to install Linux on one of the Powerbooks I haven't had the motivation to get rid of and try it just to say I did.
