Yes, it appears you can - found this guide on the Wayback archive. I'm sure the 2026 version can be a bit more elegant maybe than chopping out slots maybe with a long DVI cable and jack.
There also exists the Apple DVI to ADC adapter (model A1006) which does all this in a much more elegant way. Keep an eye out for them, the couple I came across recently were dirt cheap as nobody uses DVI nor these display anymore.
This would be the ideal solution but they're mad expensive. I'll look out for one of these, but if i don't find one, I'll probably try to create a replacement or something
