TashRouter: An AppleTalk Router
So, for the moment, anyway, I have inserted AppleTalkPort into the class hierarchy between Port and EtherTalkPort/LocalTalkPort. Only change that should be required to your router configuration is to change
from tashrouter.port.localtalk.tashtalk import TashTalkPort
to
from tashrouter.port.appletalk.localtalk.tashtalk import TashTalkPort
and suchlike.
Rambling/rubber-duck-debugging ahead, again.
I have AURP on the brain. I've tried to get through the spec before and was only met with an overwhelming sense that I'd rather be doing anything else, but lately the gears have started to turn a little. It's not hard to imagine how I'd rig up a mechanism for RoutingTable and ZoneInformationTable to let an entity subscribe to their changes - this instead of the rather redundant and silly RTMP/ZIP-to-AURP translation layer that the AURP spec suggests - which makes the whole affair seem more possible than it has in the past. The question I'm facing now is, oddly, how to organize it? TashRouter has the concept of Services, which are usually-threaded entities optionally with a DDP socket number that the Router will deliver Datagrams to when they come in with that destination socket number... but those are AppleTalk specific (maybe they should be renamed AppleTalkServices?), so AURP doesn't belong there. TashRouter also has the concept of Ports, which are hierarchically-organized, like Port > AppleTalkPort > LocalTalkPort > TashTalkPort, with each layer adding reusable functionality along the way, but AURP isn't really a port type, it's a concept used by multiple disparate port types. It can, for example, be used as the routing protocol for AppleTalk over PPP, but that's just one among many; it can also be used over UDP/IP, which is, if I'm not mistaken, what GlobalTalk uses, and given how open-ended the spec seems to be, it wouldn't surprise me to learn it can go over IPX, NetBIOS, IrDA, and carrier pigeon, too. So where in the code does it belong? Do I just throw my hands up and drop it in the root directory along with Datagram? I'm thinking about it...
Maybe there are three hard problems in computer science: cache invalidation, naming things, organizing things, and off-by-one errors...
AURP is straight wrapping DDP-in-UDP packets, with a IP only side-band protocol to manage large-scale network routing updates (in place of RTMP) to reduce broadcast traffic over what was bandwidth limited broadband links. Its over engineered and typical Apple NIH, which is likely why the two largest players in the router market, Shiva and Cayman Systems, developed their own protocols.
Whats nice about AURP is that it can be seamlessly upgraded to support IPv6. I'll also give credit for Apple being forward looking in their design and only using one port for communication as it makes running this over NAT much easier.
I don't think this is true; RFC1378 talks about using AURP for routing information exchange but embeds DDP packets directly in PPP frames, with no IP encap. AURP as a protocol is distinct from the encapsulation scheme that AIR happens to use.
edit: the spec section of RFC1504 is horrible, but it does specifically mention IP encap as only one of the options available for tunneling for use with AURP - point to point WAN links where DDP is sent directly over the data link is mentioned as another, so it's not safe to assume IP encap certainly
