Apple Lisa minimal card setup
robin-fo
68000
Hi everyone, especially our Lisa experts here!
@AlexTheCat123 @warmech @RolandJuno
I'll hopefully soon test the Lisa Replica PCBs I've been assembling for a year or so now...
I have the following question: A Lisa can boot with the Motherboard and CPU card only – right? It will report an error obviously, but you'll have something on the screen at least. How is this possible if the soft power is controlled by the IO card? Do I simply have to switch on the PSU manually? I'm using the Lisa Breakout PCB for now. https://github.com/RolandJuno/Lisa_Breakout
Many thanks in advance,
Robin
What am I, chopped liver? Sheesh.
I'll show you --- I'm going to march right upstairs, pull the card cage out of the 2/10 and yank out all but the CPU card and report back.
The results are as follows:
With only a CPU board, the Lisa turns on immediately after power is applied, and the screen shows garbage:
(note: flashing images on the screen) https://photos.app.goo.gl/ss45GQ9gsFnigvCMA
With a CPU board and RAM populated, the Lisa still turns on immediately, showing an Error 41 on the CPU board as it continually redraws the screen. Retrace lines are visible.
(note: flashing images on the screen) https://photos.app.goo.gl/kgRQf9f5p2aYeNge6
YOU'RE WELCOME :p
Sorry I forgot to mention you in the list of Lisa experts 😉😅
Many thanks for checking, this is very kind of you!
So I need a working RAM card as well… I have two genuine ones in unknown condition, but with some signs of corrosion. I‘ll have to try them.
Composite output will work in that condition I guess?
It depends: even though the garbage isn't much to look at, it's still informative. The screen image is still a raster, so if you see it, that means the video state ROM and other video gubbins are working at least, and that ain't nothing! Here's where you really do want to hear from folks like the ones you've tagged: I'm not sure to what extent that screen means the CPU is executing code. They may know.
Composite output should work to show you the screen junk.
Good luck with your build!
I get nice waveforms out of the Video / Sync / Composite signals. However, I don't have my old B/W TV at hand currently.. I have a Samsung Smart TV, but it doesn't sync to the composite video output apparently. Is this to be expected? Could I convert the Video + HSYNC + VSYNC signals to VGA? Or would I have similar issues as with the IIgs RGB output and modern displays?
Lisa video has a horizontal frequency of 22 or so KHz; it's very odd and few monitors sync to it natively. Most people who use the composite jack use something like an RGBtoHDMI to see the video.
I've heard of people using a differently-configured RGBtoHDMI to interpret the separated signals you mention. It may be possible to do the usual buffering+level shift trick to see if a really tolerant VGA monitor can handle the signal, but I've never heard of anyone doing that. The Lisa screen geometry and refresh rate seem like they'd present a real challenge to most displays.
An oscilloscope may show that you're getting a video signal with the correct horizontal frequency; this by itself would be a good sign that the video system is working at some level. Based on your post it seems you may have already confirmed that things look good on a 'scope...
With my CPU card and an original RAM card of unknown condition, I get this with the RGBtoHDMI:
View attachment IMG_6503.mov
So I really have some kind of raster, however there are some bad pixels, that mess in the upper part and there is no real trace of the error dialog. It appears as the system is not booting at all or even in a reset loop.
Any ideas where to look next?
Forgive this post for being quite similar to the one on the other active Lisa troubleshooting thread, but: you now find yourself at the beginning of a classic troubleshooting journey, for which the typical strategies for machines of the Lisa's era apply. Unlike the other poster, you will have easy access to your CPU board and can begin probing. Before we begin: what troubleshooting equipment do you possess? Multimeter, oscilloscope, logic analyser, anything else of that nature?
Your hypothesis of the system not booting at all seems like one worth checking. For me, the trinity of first troubleshooting checks are as follows:
1. Are all of your voltages good?
2. Is your CPU receiving a clock signal?
3. Is your CPU coming out of reset?
Finally, as you will have hand-assembled your computer, you will have soldered thousands of individual joints, which is a difficult thing to do without making any mistakes. This sort of passage from a Heathkit assembly manual is also relevant, particularly at this early stage:
There may be people who will recognise the problem you're dealing with from the appearance of your raster, but I am not one of them. A post on lisalist2.com might be more likely to reach such an expert.
After trying Slot 2 again (it didn‘t work before) and burning a last EPROM for the IO board, my Lisa now magically boots (sort of)..
However, the same card in Slot 1 still shows the same symptoms, but since both slots should be identical except the A15 signal which is n/c in Slot 1 and DGND in Slot 2 and the T[1..3] and S[1..3] this is somehow mysterious… Maybe clean the (brand new) connector?
I suspect some RAM ICs to be bad and likely also some 74xx logic on the (slightly battery damaged) RAM card. Maybe it‘s just trace damage though…
