G4 MDD RAM recognised at wrong size
I finally upgraded the RAM in my G4 MDD Powermac; it's originally an 867MHz DP model, upgraded to 1.25GHz DP with a bus speed modification.
I had a single 512MB stick of PC2700 RAM in the machine, and tried to max it out to 2GB with a pair of 1GB PC2700 sticks.
I've found, however, that both 1GB sticks are recognised as 512MB PC2600 sticks instead. Research suggests that the PC2600 report is just a quirk of some MDD models, but I was able to put my old 512MB stick in, and it reports exactly as the 1GB sticks do.
Do I have bad/mislabelled RAM? Or is there a 512MB per slot limit on the machine?
I was under the impression others had maxed RAM on such machines with two 1GB sticks, but perhaps that only works on the later MDD models?
It seems stable, and much happier in its current configuration, at least, and getting it up to 1.5GB is the max OS9 can handle anyway, to my recollection... but it's still odd, and I'm hoping someone can clarify what's happening for me, because I've not found anything about RAM being read/used at half its size, or any maximum per stick.
Use Open Firmware to dump the SPD info from the DIMMs using I2C. The SPD data will indicate the size and layout of the DIMMs.
https://68kmla.org/bb/threads/g4-yi...stem-profiler-being-unknown.48707/post-547169
https://68kmla.org/bb/threads/imac-g3-rev-a-c-g4-cpu-upgrade.5043/post-564439
What version of Open Firmware does your G4 have? We can check the HWInit code to see how it interprets the SPD data.
If the SPD data is correct but the HWInit does not use the info correctly, then maybe we can adjust some registers in the memory controller.
Output from dump-device-tree in Open Firmware (use telnet to capture it over Ethernet) may also include SPD info and other memory and memory controller info.
https://forums.macrumors.com/thread...5-ram-shenanigans-to-18gb-and-beyond.2482947/
I could only get 1GB DIMMs to work in my MDD back then by not using neighboring slots, otherwise they would show up as 512MB just like they do for you. Try 1GB DIMMs in J20 and J22 leaving J21 and J23 free (or the other way around with sticks in J21 and J23 leaving J20 and J22 free)
That was actually the first thing I tried, and how they are currently arranged, just with an additional 512 stick in J21 to boost it to 1.5GB - the J23 slot apparently ceases to work after the bus speed mod.
This seems a smidge above my level, tbh; I'll have to get my partner to take a look and give it a try. Much appreciated!
Would be interesting to compare SPD of your working 1 GB DIMMs with DanaTheElf's non-working 1 GB DIMMs.
I don't remember ever seeing this limitation, but most of my experience is probably with the later versions (I think there are at least 5 different MDD logic board versions). I know the "PC3200" modules have worked for me. In a few cases I've used two 1GB modules on one end of the bank for heatsink clearance:
68kmla.org/bb/threads/mdd-heatsink-upgrade.41488/
I've got a bunch of 512MB PC-3200 DIMMs that I pulled out of my early 2005 PM G5. Four of those should max you out if you're interested.
Kind offer, but only three slots work after the bus upgrade, so I'm hitting the 3-slot max anyway.
I really don't know my way around OFW, and have no idea if this is what you were looking for; this is the best I was able to get, but maybe it makes sense to you? (Copied into text file from OFW over telnet.)
The .properties command will truncate large properties. Use this to dump the entire contents of the dimm-info property.
Code:
" /memory" find-package if " dimm-info" rot get-package-property if ." property not found" cr else dump then then
For the i2c method, try this:
Code:
" ui2c" select-dev
h# 100 buffer: buf
cr 80 0 do buf 80 i 2* 0 read-i2c-at ?dup if i 2* 2 u.r buf swap dump cr then loop
Other info that might be useful:
Code:
devalias
dump-device-tree
Code:
Code:
" ui2c" select-dev
h# 100 buffer: buf
Code:
devalias
dump-device-tree
0 > " /memory" find-package if " dimm-info" rot get-package-property if ." property not found" cr else dump then then
ff9cd8ac: 80 08 07 0d 0b 01 40 00 04 60 70 00 82 08 00 01 |......@..`p.....|
ff9cd8bc: 0e 04 0c 01 02 20 c0 75 70 00 00 48 30 48 2a 80 |..... .up..H0H*.|
ff9cd8cc: 80 80 45 45 00 00 00 00 00 3c 48 30 2d 55 00 00 |..EE.....<H0-U..|
ff9cd8dc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 67 |...............g|
ff9cd8ec: ce 00 00 00 00 00 00 00 01 4d 33 20 36 38 4c 36 |.........M3 68L6|
ff9cd8fc: 35 32 33 42 54 4e 2d 43 42 33 20 4e 42 04 18 41 |523BTN-CB3 NB..A|
ff9cd90c: 07 84 78 00 59 41 53 37 39 30 41 00 00 00 00 00 |..x.YAS790A.....|
ff9cd91c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ff9cd92c: 80 08 07 0d 0a 02 40 00 04 60 70 00 82 08 00 01 |......@..`p.....|
ff9cd93c: 0e 04 0c 01 02 20 c0 75 70 00 00 48 30 48 2a 40 |..... .up..H0H*@|
ff9cd94c: 80 80 45 45 00 00 00 00 00 3c 48 3c 2d 55 00 00 |..EE.....<H<-U..|
ff9cd95c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 |...............#|
ff9cd96c: 7f 7f fe 00 00 00 00 00 4b 45 42 44 35 32 55 43 |........KEBD52UC|
ff9cd97c: 38 41 4d 46 41 2d 36 42 20 20 20 30 20 28 04 46 |8AMFA-6B 0 (.F|
ff9cd98c: f8 fd e1 4d 00 00 00 00 00 00 00 00 00 00 00 00 |...M............|
ff9cd99c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ff9cd9ac: 80 08 07 0d 0b 01 40 00 04 60 70 00 82 08 00 01 |......@..`p.....|
ff9cd9bc: 0e 04 0c 01 02 20 c0 75 70 00 00 48 30 48 2a 80 |..... .up..H0H*.|
ff9cd9cc: 80 80 45 45 00 00 00 00 00 3c 48 30 2d 55 00 00 |..EE.....<H0-U..|
ff9cd9dc: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 67 |...............g|
ff9cd9ec: ce 00 00 00 00 00 00 00 01 4d 33 20 36 38 4c 36 |.........M3 68L6|
ff9cd9fc: 35 32 33 42 54 4e 2d 43 42 33 20 4e 42 04 18 41 |523BTN-CB3 NB..A|
ff9cda0c: 07 84 78 00 59 41 53 37 39 30 41 00 00 00 00 00 |..x.YAS790A.....|
ff9cda1c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ff9cda2c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ff9cda3c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ff9cda4c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ff9cda5c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ff9cda6c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ff9cda7c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ff9cda8c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ff9cda9c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| ok
0 > " ui2c" select-dev ok
0 > h# 100 buffer: buf ok
0 > cr 80 0 do buf 80 i 2* 0 read-i2c-at ?dup if i 2* 2 u.r buf swap dump cr then
58
ffbc4700: f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 |................|
ffbc4710: f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 |................|
ffbc4720: f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 |................|
ffbc4730: f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 |................|
ffbc4740: f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 |................|
ffbc4750: f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 |................|
ffbc4760: f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 |................|
ffbc4770: f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 f5 |................|
62
ffbc4700: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
ffbc4710: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
ffbc4720: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
ffbc4730: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
ffbc4740: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
ffbc4750: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
ffbc4760: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
ffbc4770: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
6c
92
ffbc4700: 20 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ...............|
ffbc4710: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ffbc4720: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ffbc4730: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ffbc4740: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ffbc4750: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ffbc4760: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
ffbc4770: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
a0
ffbc4700: 80 08 07 0d 0b 01 40 00 04 60 70 00 82 08 00 01 |......@..`p.....|
ffbc4710: 0e 04 0c 01 02 20 c0 75 70 00 00 48 30 48 2a 80 |..... .up..H0H*.|
ffbc4720: 80 80 45 45 00 00 00 00 00 3c 48 30 2d 55 00 00 |..EE.....<H0-U..|
ffbc4730: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 67 |...............g|
ffbc4740: ce 00 00 00 00 00 00 00 01 4d 33 20 36 38 4c 36 |.........M3 68L6|
ffbc4750: 35 32 33 42 54 4e 2d 43 42 33 20 4e 42 04 18 41 |523BTN-CB3 NB..A|
ffbc4760: 07 84 78 00 59 41 53 37 39 30 41 00 00 00 00 00 |..x.YAS790A.....|
a2
ffbc4700: 80 08 07 0d 0a 02 40 00 04 60 70 00 82 08 00 01 |......@..`p.....|
ffbc4710: 0e 04 0c 01 02 20 c0 75 70 00 00 48 30 48 2a 40 |..... .up..H0H*@|
ffbc4720: 80 80 45 45 00 00 00 00 00 3c 48 3c 2d 55 00 00 |..EE.....<H<-U..|
ffbc4730: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 |...............#|
ffbc4740: 7f 7f fe 00 00 00 00 00 4b 45 42 44 35 32 55 43 |........KEBD52UC|
ffbc4750: 38 41 4d 46 41 2d 36 42 20 20 20 30 20 28 04 46 |8AMFA-6B 0 (.F|
ffbc4760: f8 fd e1 4d 00 00 00 00 00 00 00 00 00 00 00 00 |...M............|
a4
ac
ca
ffbc4700: ff ff 46 18 34 ff ff ff ff ff ff ff ff ff ff ff |..F.4...........|
ok
0 > devalias
pci0 /pci@f0000000
agp /pci@f0000000
pci1 /pci@f2000000
pci2 /pci@f4000000
ui2c /uni-n/i2c
ui2c-serial /uni-n/i2c/cereal
keyboard /pseudo-hid/keyboard
mouse /pseudo-hid/mouse
sound /pseudo-sound
eject-key /pseudo-hid/eject-key
nvram /nvram
enet /pci@f4000000/ethernet
fw /pci@f4000000/firewire
pci /pci@f2000000
usb0 /pci@f2000000/usb@18
usb1 /pci@f2000000/usb@19
mac-io /pci@f2000000/mac-io@17
mpic /pci@f2000000/mac-io@17/interrupt-controller
hd /pci@f4000000/ata-6@d/disk@0
cd /pci@f2000000/mac-io@17/ata-3@20000/disk@0
ide0 /pci@f2000000/mac-io@17/ata-3@20000/disk@0
ide1 /pci@f2000000/mac-io@17/ata-3@20000/disk@1
ultra0 /pci@f4000000/ata-6@d/disk@0
ultra1 /pci@f4000000/ata-6@d/disk@1
scca /pci@f2000000/mac-io@17/escc/ch-a
sccb /pci@f2000000/mac-io@17/escc/ch-b
ki2c /pci@f2000000/mac-io@17/i2c
ki2c-serial /pci@f2000000/mac-io@17/i2c/cereal
via-pmu /pci@f2000000/mac-io@17/via-pmu
rtc /pci@f2000000/mac-io@17/via-pmu/rtc
pi2c /pci@f2000000/mac-io@17/via-pmu/pmu-i2c
wireless /pci@f2000000/mac-io@17/@30000
ultra2 /pci@f2000000/mac-io@17/ata-4@1f000/disk@0
ultra3 /pci@f2000000/mac-io@17/ata-4@1f000/disk@1
cd1 /pci@f2000000/mac-io@17/ata-3@20000/disk@1
fan /uni-n/i2c/fan
veo0 /vsp@f9000000/veo@f9080000
veo1 /vsp@f9000000/veo@f9180000
last-boot /pci@f4000000/ethernet@f
screen /pci@f0000000/ATY,PheonixParent@10/ATY,Pheonix_A@0
ok
And device tree dump attached in a txt file, because it's obnoxiously large.
When pasting text output in a forum post, first paste it into a text editor like BBEdit.app to make sure copying from Terminal.app does not double space all the text (because of windows CRLF characters?). Then copy from the text editor into the forum post with [code] at the beginning and [/code] at the end. This will preserve indenting and extra spaces used for aligning columns of text and the output will be displayed using a monospaced font.
I see you ROM version Apple PowerMac3,6 4.4.7f1 BootROM built on 09/10/02 at 14:50:40. I don't have that one yet. Consider dumping a copy before doing any firmware updates.
https://68kmla.org/bb/threads/does-anyone-have-a-667mhz-or-800mhz-powerbook-g4.50929/post-573844
I think you may be able to update your firmware to 4.4.8f2.
https://forums.macrumors.com/threads/powerpc-mac-firmware-boot-rom-updates.2285855/
I don't know what if anything the new firmware improves. I could compare it to 4.4.7f1 if you provide a dump (get the before and after firmwares for a proper compare).
Now we have all the SPD info from your DIMMs.
dimm-info from .properties shows the hex from the first 2 DIMMs (128 bytes per DIMM, 256 bytes total).
The get-package-property method shows the hex for all three DIMMs and has zeros for the unpopulated fourth DIMM slot (512 bytes total).
The i2c output has the same hex for the three installed DIMMs at i2c addresses A0, A2, and A4. I guess the fourth DIMM would have SPD at i2c address A6 (one might call these address 50, 51, 52, and 53 - I'm not sure what the proper convention is - the least significant bit is a read/write flag where 0 = read which is what we are doing).
Have you tried booting with just a single DIMM? Try all three individually.
The DIMMs at i2c address A0 and A4 are identical. Try this pair by itself.
I used spd_tool from gitgub to parse the SPD. Linux has a utility decode-dimms to do similar.
Code:
mkdir -p /Volumes/Work/Programming/spd_tool
cd  /Volumes/Work/Programming/spd_tool
#git clone https://github.com/rigred/spd_tool.git rigred-spd_tool
cd /Volumes/Work/Programming/spd_tool/rigred-spd_tool
xxd -p -r <<< '
> /tmp/DIMM_A0.bin
xxd -p -r <<< '
> /tmp/DIMM_A2.bin
python3 spd_tool.py dump --spd /tmp/DIMM_A0.bin --programmer > /tmp/DIMM_A0.txt
python3 spd_tool.py dump --spd /tmp/DIMM_A2.bin --programmer > /tmp/DIMM_A2.txt
bbdiff /tmp/DIMM_A0.txt /tmp/DIMM_A2.txt
I don't know how to calculate the DIMM size from the SPD info. I come up with 512 MiB. spd_tool might skip some info.
Code:
# DIMM size = 2^(rows + columes) * (width/8) * module_banks * SDRAM_banks
#A0
bc <<< "scale=0; 2^(13+11)*(64/8)*1*4"
536870912
#A2
bc <<< "scale=0; 2^(13+10)*(64/8)*2*4"
536870912
It would be helpful to get SPD info from someone with working 1 GiB DIMMs in a G4.
Hey, sorry for the delay - been busy with other things.
Hopefully I did it right:
Well, it took a while to get linux all set up on my erstwhile MDD, but here is the "raw" SPD for a working 1024MB DIMM. I do have to skip a slot, and I vaguely remember something weird about some modules I scrounged from PCs in the 2000s not working despite being PC2700+. I guess 2 ranks does work though.
Code:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 80 08 07 0d 0b 02 40 00 04 50 70 00 82 08 00 01    ??????@.?Pp.??.?
10: 0e 04 1c 01 02 20 c0 60 70 75 75 3c 28 3c 28 80    ????? ?`puu<(<(?
20: 60 60 40 40 00 00 00 00 00 37 46 28 28 50 00 00    ``@@.....7F((P..
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a8    ...............?
40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
80: 47 57 00 00 00 00 00 00 00 00 00 00 00 00 00 00    GW..............
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
and
Code:
decode-dimms -x spdfile
gives
Code:
---=== SPD EEPROM Information ===---
EEPROM Checksum of bytes 0-62                    OK (0xA8)
# of bytes written to SDRAM EEPROM               128
Total number of bytes in EEPROM                  256
Fundamental Memory type                          DDR SDRAM
SPD Revision                                     0.0
---=== Memory Characteristics ===---
Maximum module speed                             400 MT/s (PC3200)
Size                                             1024 MB
Banks x Rows x Columns x Bits                    4 x 13 x 11 x 64
Ranks                                            2
Voltage Interface Level                          SSTL 2.5V
Module Configuration Type                        No Parity
Refresh Rate                                     Reduced (7.8 us) - Self Refresh
Supported CAS Latencies                          3T, 2.5T, 2T
Supported CS Latencies                           0
Supported WE Latencies                           1
tCL-tRCD-tRP-tRAS                                3-3-3-8 as DDR-400
                                                 2.5-3-3-7 as DDR-333
                                                 2-2-2-6 as DDR-266
Minimum Cycle Time                               5 ns at CAS 3
                                                 6 ns at CAS 2.5
                                                 7.5 ns at CAS 2
Maximum Access Time                              0.7 ns at CAS 3
                                                 0.7 ns at CAS 2.5
                                                 0.75 ns at CAS 2
Maximum Cycle Time (tCK max)                     10.0 ns (DDR-200)
---=== Timings at Standard Speeds ===---
tCL-tRCD-tRP-tRAS as DDR-400                     3-3-3-8
tCL-tRCD-tRP-tRAS as DDR-333                     2.5-3-3-7
tCL-tRCD-tRP-tRAS as DDR-266                     2-2-2-6
tCL-tRCD-tRP-tRAS as DDR-200                     2-2-2-4
---=== Timing Parameters ===---
Address/Command Setup Time Before Clock          0.60 ns
Address/Command Hold Time After Clock            0.60 ns
Data Input Setup Time Before Clock               0.40 ns
Data Input Hold Time After Clock                 0.40 ns
Minimum Row Precharge Delay (tRP)                15.00 ns
Minimum Row Active to Row Active Delay (tRRD)    10.00 ns
Minimum RAS# to CAS# Delay (tRCD)                15.00 ns
Minimum RAS# Pulse Width (tRAS)                  40.00 ns
Minimum Active to Active/AR Time (tRC)           55.00 ns
Minimum AR to Active/AR Command Period (tRFC)    70.00 ns
Maximum DQS to DQ Skew (tDQSQ)                   0.40 ns
Maximum Read Data Hold Skew (tQHS)               0.50 ns
---=== Module Attributes ===---
---=== Manufacturing Information ===---
Manufacturer                                     Undefined
Part Number                                      Undefined
Number of SDRAM DIMMs detected and decoded: 1
and
Code:
gives
Code:
Size                                             1024 MB
I found decode-dimms at https://github.com/Sensirion/i2c-tools
It's a perl script which works in macOS Monterey on my Mac.
It says the DIMMs from @DanaTheElf are only 512 MB.
Looking up their part numbers "EBD52UC8AMFA-6B" and "M3 68L6523BTN-CB3" results in descriptions that also say 512 MB.
@DanaTheElf , maybe you forget to insert the 1 GB DIMMs before capturing the SPD info?
