G4 Yikes! and ECC RAM (also, the reported speed and type for all RAM in System Profiler being 'unknown')
I recently picked up a nice PowerMac G4 350Mhz Yikes! model.
It came with a lowly 64MB PC100 DIMM, and I thought I should probably increase it so that I could at least get 10.4 installed on there.
I was lent 2x 128MB ECC DIMMs, and installed them, and it booted up just fine. However, Phipli looked up the schematic for the G4 Yikes! model, and found that the ECC lines for J19 (DIMM slot 1) are reserved for some sort of custom Apple ROM. Which is likely why Apple recommends not using ECC RAM. I immediately shut off the machine, and switched the ECC to being in the other slots, and placed a regular DIMM into J19 (slot 1).
Upon boot, I discovered that the RAM type and speed are reported as 'unknown' in System Profiler under Tiger 10.4. I then swapped out the ECC DIMMs, and it still reports this way. I reset open firmware (just in case) and same thing.
My question to those here is: does yours show a type and speed under System Profiler, or does yours say 'unknown' as well? Did I fubar something?
Lastly, because the first slot seems to reserve the ECC data lines for a custom Apple ROM of some sort, on the Yikes! board, would this also happen on other boards? If so, would it only be the first slot that would do this, or would it be other slots (and not always the first one)?
If anyone knows, I'm rather intrigued with this. I'd like to try these ECC DIMMs in other machines to see if they work, out of morbid curiosity. I don't want to ruin anything, especially considering my G4 now reports type and speed as 'unknown'.
Your thoughts and considerations and experiences welcome!
Use Open Firmware or whatever to read the SPD (Serial Presence Detect) from each of the DIMMs. I think it's 128 bytes each.
https://en.wikipedia.org/wiki/Serial_presence_detect
The I2C addresses for the DIMM slots are 50, 51, 52, and 53 (hex).
Use read-iic ( len offset addr*2 ) in a loop to look for i2c devices
Code:
dev via-cuda
cr 80 0 do 80 0 i 2* read-iic ?dup if cr i . dump cr then loop
For my G3 Yosemite, it finds 3 DIMM slots (50, 51, 52; 53 is empty), and something related to the Sonnet G4 1GHz ZIF is at 54. There's something at 31 but it's all FF.
Thanks to MacDat website, I found the specs for many other models.
It looks like the Apple Boot ROM address lines are unique to the G3 blue and White and the G4 Yikes! Likely because those two boards are nearly identical.
It seems like at least the 3 memory slot G4s like the digital audio do not have the Apple boot ROM notation for the first slot.
I haven’t been able to locate schematics for the other models that might be affected, namely Sawtooth and AGP Graphics and Gigabit Ethernet, etc.
I’m thinking it’s likely the 4 slot boards have these address lines for the first memory slot, and the 3 slot boards do not.
If you look at the history, the beige G3 had 3 memory slots and a ROM slot. The blue and white G3 had 4 memory slots and slot 1 shared lines for a custom Apple boot ROM. The Yikes! model is basically a G3 B&W so it shares the same.
The digital audio specs are on MacDat and do not seem to indicate any address lines for the Apple ROM on the 3 memory slots.
My theory is that Apple stopped doing that when not using 4 slots.
So for now it seems it might be a bad idea to use ECC memory in any G3 or G4 memory slot one, on 4 memory slot boards. Unsure if using an ECC DIMM in the slot where lines are used for an Apple boot ROM causes issues or damage.
Thoughts on whether it causes damage? Issues can easily be tested for. I could plop a single ECC DIMM into slot J19 (slot 1) and run a memory test over and over, and leave it running for 24 hours. Just worried about damage.
Use Open Firmware or whatever...
That's neat! Do you know of a way besides Open Firmware to do this? What about a way to write to these EEPROMs? Right now I have to remove them, program them, and then re-solder them. There are PC133 RAM sticks that will work fine at CL2, but I don't know of another way to set them for this in a mac.
There's probably an I2C API to read them. As a last resort, you could translate the Open Firmware code.
For writing, I suppose you would have to look up the data sheet of the I2C device to see if that is actually possible from I2C.
You mean the PC133 doesn't claim CL2 but can use CL2 if used as PC100? Or it works with CL2 as PC133 even though it doesn't claim CL2?
I don't know how Macs deal with the SPD data or if you can change it programatically.
The ERS documentation doesn't say much about SPD.
On the Mac, it seems like the memory timings come straight off the SPD. So the only way I know of to try different settings is to reprogram the EEPROM. On old fashioned DOS computers there are usually a bunch of BIOS settings to tinker with for these timings, often with a default to the effect "By SPD" to use settings from the RAM module. There is also a way on DOS to rewrite the EEPROM and in fact I use Virtual PC to run some software to more easily edit the data. But then to program the stick I have to un-solder the chip, etc...
What does the EEPROM on your Sonnet have to say? I would guess it has the settings for the L3 cache.
Some Macs also have temperature sensors on the i2c bus. I wonder if the Mini temperatures could be found there.
Code:
\ Use read-iic ( len offset addr*2 -- addr len | false ) in a loop to look for i2c devices
dev via-cuda
31
ff86b87b: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff :................:
ff86b88b: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff :................:
ff86b89b: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff :................:
ff86b8ab: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff :................:
ff86b8bb: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff :................:
ff86b8cb: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff :................:
ff86b8db: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff :................:
ff86b8eb: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff :................:
50
ff86b87b: 80 08 04 0c 0a 02 40 00 01 75 54 00 80 08 00 01 :......@..uT.....:
ff86b88b: 8f 04 04 01 01 00 0e a0 60 ff ff 14 0f 14 2d 20 :........`.....- :
ff86b89b: 15 08 15 08 ff ff ff ff ff ff ff ff ff ff ff ff :................:
ff86b8ab: ff ff ff ff ff ff ff ff ff ff ff ff ff ff 12 92 :................:
ff86b8bb: 97 61 00 00 00 00 00 00 46 16 64 08 08 00 00 00 :.a......F.d.....:
ff86b8cb: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 :................:
ff86b8db: 00 00 00 07 00 00 00 00 00 00 00 00 00 00 00 00 :................:
ff86b8eb: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 ad :..............d.:
51
ff86b88b: 8f 04 06 01 01 00 0e a0 60 00 00 14 0f 14 2c 20 :........`....., :
ff86b89b: 15 08 15 08 00 00 00 00 00 00 00 00 00 00 00 00 :................:
ff86b8ab: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 af :................:
ff86b8bb: 2c ff ff ff ff ff ff ff 02 31 36 4c 53 44 54 33 :,........16LSDT3:
ff86b8cb: 32 36 34 41 47 2d 31 33 33 42 31 01 00 01 08 33 :264AG-133B1....3:
ff86b8db: 09 f7 95 00 00 00 00 00 00 00 00 00 00 00 00 00 :................:
ff86b8eb: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 ff :..............d.:
52
ff86b8bb: 2c ff ff ff ff ff ff ff 08 31 36 4c 53 44 54 33 :,........16LSDT3:
ff86b8cb: 32 36 34 41 47 2d 31 33 33 42 31 01 00 01 0b 62 :264AG-133B1....b:
ff86b8db: 05 ee 9f 00 00 00 00 00 00 00 00 00 00 00 00 00 :................:
54
ff86b87b: 80 08 00 00 00 40 00 1e 01 00 00 00 00 00 00 00 :.....@..........:
ff86b88b: 02 00 04 c8 00 00 10 00 00 00 00 00 00 00 00 00 :................:
ff86b89b: 01 e8 03 64 00 00 00 00 00 00 00 00 00 00 00 00 :...d............:
ff86b8ab: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 :................:
ff86b8bb: 53 4f 4e 54 45 47 56 00 00 00 00 00 00 00 00 00 :SONTEGV.........:
ff86b8cb: 00 00 00 00 00 00 00 00 00 00 00 05 37 34 35 35 :............7455:
ff86b8db: 00 00 00 00 65 53 4f 4e 4e 45 54 20 54 45 43 48 :....eSONNET TECH:
ff86b8eb: 4e 4f 4c 4f 47 49 45 53 00 ff ff ff ff ff ff ff :NOLOGIES........:
- SPD (Serial Presence Detect) at 50,51,52, (53 is empty).
- Sonnet G4 ZIF at 54.
- ? at 31.
I believe the contents of I2C address 54h are described by
https://www.nxp.com/docs/en/data-sheet/MPCPCMEC.pdf
Thanks @LightBulbFun for finding that.
Has anyone looked at the I2C stuff on other Macs? I can't really find any documentation, but I know the MDD has an I2C sensor on the CPU that can be read by Temperature Monitor. As an experiment I removed one of these sensors and hooked it up on a CPU from an AGP. The sensor did not appear in Temperature Monitor, but CPU Director could see it. Although the calibration was off it was definitely reading the senor because I could heat/cool it and watch the plot change accordingly.
I think this shows that with some firmware improvements temperature sensors could be added and read. Also, there may be existing sensors that could be read.
cuda is just one i2c bus. There could be other buses. For example, each VGA or DVI port is its own i2c bus (EDID has address 0x50 and DDC has address 0x30).
Does CPU Director use i2c to read the temperature, or is it using an API or is it examining values in ioreg or some other location? Or is it a CPU register? Maybe disassembling it can give the answer.
I think CPU Director must be reading the I2C bus. On the DA schematic this bus connects to the CPU, DIMMs, and Uni-N. I would suppose the MDD is set up the same way, so I wonder if some piece of the MDD firmware could be copied (or enabled?) to other versions to read the sensor. I don't think Temperature Monitor does anything so low-level to work. I'm guessing the difference is in the MDD firmware.
Some of the G4 PowerBook models have sensors that Temperature Monitor can see, and there are a few schematics around for those that might show something similar.
Section 10.4.2.3 of IBM PowerPC 750FX RISC Microprocessor User’s Manual explains one method of getting the approximate junction temperature from the TAU (Thermal Assist Unit) using the THRM1,2,3 registers.
More information exists in "Programming the Thermal Assist Unit in the MPC750 Microprocessor"
https://www.nxp.com/docs/en/application-note/AN1800.pdf
The previously linked document https://www.nxp.com/docs/en/data-sheet/MPCPCMEC.pdf documents a couple values in the SPD that relate to translating TAU values into temperature but these aren't mentioned in the "Programming the Thermal Assist Unit in the MPC750 Microprocessor" document?
Some G4's don't have a TAU.
The MDD CPU boards and some of the Powerlogix/Newer Technology boards have a separate temperature sensor chip installed and connected to the I2C bus (which may also have an EEPROM installed/connected). In the MDD, this chip automatically shows up in Temperature Monitor. I assume this works based on a combination of the firmware and maybe some part of OS X that makes the values available to software. On the "Graphite" series of computers the I2C components on the CPU board can be read by CPU Director.
I looked at one of the PowerBook schematics and it has a fan controller chip that has sensor inputs and fan outputs. This also connects to the DIMM/Uni-N I2C bus and I would guess there is a similar process that allows the temperature readings (and fan speeds) to be accessible by software.
Earlier I had tried those open firmware commands on other Macs but couldn't get them to work. Looking at it again, there is probably different syntax needed. The AGP with firmware 4.2.8f1 has a uni-north i2c device, and different commands there. So I tried:
Code:
dev ui2c
cr 80 0 do 80 0 i 2* i2c-read ?dup if cr i . dump cr then loop
This resulted in a ~2s delay, then the computer turned off. At least it didn't give an error message, so it may be closer to working.
