I recently picked up a nice PowerMac G4 350Mhz Yikes! model.
It came with a lowly 64MB PC100 DIMM, and I thought I should probably increase it so that I could at least get 10.4 installed on there.
I was lent 2x 128MB ECC DIMMs, and installed them, and it booted up just fine. However, Phipli looked up the schematic for the G4 Yikes! model, and found that the ECC lines for J19 (DIMM slot 1) are reserved for some sort of custom Apple ROM. Which is likely why Apple recommends not using ECC RAM. I immediately shut off the machine, and switched the ECC to being in the other slots, and placed a regular DIMM into J19 (slot 1).
Upon boot, I discovered that the RAM type and speed are reported as 'unknown' in System Profiler under Tiger 10.4. I then swapped out the ECC DIMMs, and it still reports this way. I reset open firmware (just in case) and same thing.
My question to those here is: does yours show a type and speed under System Profiler, or does yours say 'unknown' as well? Did I fubar something?
Lastly, because the first slot seems to reserve the ECC data lines for a custom Apple ROM of some sort, on the Yikes! board, would this also happen on other boards? If so, would it only be the first slot that would do this, or would it be other slots (and not always the first one)?
If anyone knows, I'm rather intrigued with this. I'd like to try these ECC DIMMs in other machines to see if they work, out of morbid curiosity. I don't want to ruin anything, especially considering my G4 now reports type and speed as 'unknown'.
Your thoughts and considerations and experiences welcome!
