What FPS do you get in Quake on your machine?
A friendly user on the TD Discord ran some tests and posted these numbers:
- Power Mac 6500/225 overclocked to 300MHz
- 136MB RAM (8MB added onboard, 2x64MB sticks)
- stock L2 cache
- generic 2GB CF card
- Mac OS 9.1
- virtual memory on
- Screen at 256 colours 1024x768
- Quake at 320x200.
- 320x200, 29.6fps
- 320x200 (pixel doubled) 29.4fps
- 640x480, 15.5fps
They also have TERRIBLE performance when running the RAVE version, apparently the 6500 has issues with hardware acceleration when running Quake or Unreal
I ran it on 6100/60, 40MB, L2 256KB, AV card and Mac OS 7.6:
320*200 10.7fps
320*200 doubled 9.5
320*200 doubled and interlaced 10.2
640*480 3.9
320*200 10.7fps
320*200 doubled 9.5
640*480 3.9
Feel free to add it to @noglin 's proper Quake spreadsheet:
It would be the lowest RAM 6100 and slowest 6100. Oddly enough @killvore has two 6100/66/264 entries with apparently the same setup, but the first does 9.0 fps and the second 8.2.
Yours is 19% (or 30%) higher despite the lower clock speed and RAM. I guess the AV card makes all the difference (as it should)?
AV card will give slower scores. Also if you have a cache or not.
Then OS version makes a fair difference for speed on early PPCs as they ported QuickDraw and stuff from 68k.
I don't have the 6100 video cable adapter so I can't test it with the onboard video chip.
Virtual memory is off, disk cache is 96K.
I will try to remove the L2 cache stick later.
And I can update to MacOS 8.x too.
