Apple Lisa Horizontal Waviness (aka “Was There Supposed To Be A Big Plume Of Smoke?”)
Zhinü
Decided to recap my Lisa recently after a couple of people told me that the 1.8A PSU + video board can suffer from bad caps. I ordered these parts, which I later found out I forgot to order a 100uf cap for the analog board (replaced it with a 100uf cap in the order and skipped one of the 100uf caps on the PSU).
When I turned the Lisa on for the first time after recapping the boards, I instantly got a massive plume of smoke from the front left (PSU power connector/speaker area), but also the usual click when the Lisa turns on. Obviously I panicked and unplugged the Lisa, but when I went to check for a blown component, I couldn’t find anything. The caps I put on both look fine, and there’s nothing obviously burned (outside of what was burned from the original RIFAs blowing up).
Furthermore, I’m still getting some horizontal ripple on the screen, but it seems to “improve” (lack of a better word) as the Lisa stays on, which points to a cap potentially?
Any guesses on what could have gone up in smoke, and also cause horizontal ripple in the video? Sorry for the bad photos, will take better ones ASAP!
  • IMG_0720.mov
    IMG_0720.mov
    20.7 MB
All the safety caps were replaced with Kemet safety caps, the gray box ones. You can see them at the bottom of this image.
The smell seemed more electronic then like, RIFA, for lack of a better way of explaining it.
DosFox found one of the issues, he noticed that the 330uf cap was backwards on the board and bulged out. I don’t think this specifically is causing all of the issues but I replaced it with the original cap to at least rule that out.
Waviness is often caused by ripple on the DC from the main rectifier cap. Often people replace these based on just capacitance (same) and voltage (same or higher) but for some applications the ripple current spec on the part needs to be considered. If the rectifier is working mains, there is usually a low frequency rating, in Amps. If it is working on the horizontal or in a higher speed switching application there is a high frequency specification. You can see these numbers on digikey for example. For rectifier caps I try to get the largest ripple current rating for the space available. In general, the smaller the cap the lower the AC current it can tolerate.
Do you happen to know which caps on the Lisa are used for AC rectification?
