That was really painful but yes, that CPU is repaired. Had to cut away part of the exterior to get enough of the pin to solder onto. It's working, has the FPU, and I've overclocked it to 40 MHz and it's stable.
Oh well done. On that one where I fixed the two corner pins it was easier as there was more access, but I don't think I could have achieved an inline pin. I tried to repair a couple more chips after the one I sent you and I botched them both, it's very difficult to not cut too much ceramic away and then lose the exposed pin entirely. Or indeed to disturb adjacent pins which may also fall off.
Would like to know more about your methods, did you use hand tools or a machine?
I had bought one of those smaller handheld rotary tools (Fanttek F2) and used the smallest grinding bit and just went super slow. After I got about half a millimeter, I went for it and it took many attempts but finally got a bodge wire to hold tight. That was really painful.
Ran into a slight problem with the memory hack - the Viking card I have has a different layout. But it's working now. Overclock (40MHz), full 040 with FPU, and now 48MB of memory. Thanks to @croissantking!
You can see @croissantking's full instructions (super easy to follow) here:
A few months ago, I worked out how to run 48MB in a PowerBook 500 Series. Inspiration was taken from Toyoki's 64MB mod for PPC upgraded 500-Series notebooks. The concept is similar – tap into unused RAS lines on the memory controller to bump maximum RAM above 36MB.
So, how many RAS lines are unused? Let's look at the Dev Note:
DRAM_RAS_L[2–5] Row address select signals for up to four banks of DRAM. (The first two banks, selected by DRAM_RAS_L[1:0], reside on the CPU and memory module.)
That's six in total. RAS 2-5 go to the RAM connector, RAS 0 is connected to the...
Here's my attempt..
The CPU was a 33MHz L88M mask one I got from @croissantking a while back. It had one leg missing. I had to grind out about a 1mm deep by 2mm wide cutout in the ceramic. Found about 0.5mm of the missing leg left to solder onto. Took many tries but finally got it. Solder masked over it. The oscillator has been replaced with a 20MHz part which results in a 40MHz clock vs the stock 33MHz (using a 16.66MHz oscillator).
Followed @croissantking's instructions and cut traces to pins 28 and 30 on the connector, and then connected those pins to pins 190 and 191 on the memory IC. Also cut a trace heading out from pin 190. Removed all the existing memory chips as well (8 of them).
And here's the 32MB Viking memory card.. which is now 48MB.
The banks are interleaved.. so column 1 and column 3 go together, and column 2 and column 4 go together.
Everything seems to work and TattleTech reports 40MHz with FPU and 48MB of memory. I'm running it through MacBench and MacTest Pro to see how stable it is at 40MHz. My other machine has a 40MHz full 040 with FPU as well and it's been working great.
