PowerMac G4 MDD unstable after bus speed mod
I've installed a Dual 1GHz CPU in my MDD (formerly Dual 867), and bumped the bus speed to 166MHz by removing R676 on the underside of the logic board.
However, it now has RAM-related issues with stability that it didn't have before. Depending on configuration, it either fails to boot or kernels panics/freezes later on. The only configuration that seems to work is a single 1GB module in the slot nearest the CPU. If I add my other 1GB module back in, things become unstable again. FYI, both modules are PC3200.
Are the 166MHz bus MDDs usually this picky about RAM, or could it be that 133 boards don't always like being overclocked?
I've had a G4 MDD that had issues at a higher bus speed, so I underclocked it back to 133MHz. A good amount of early G4 MDDs are like that in my experience. A good idea would be to get a motherboard that is already clocked at 167MHz if you're unsuccessful with the bus overclock.
That would suggest there is some other difference between a stock 133 and stock 166 board. Perhaps there is another option resistor that needs to be set (voltage?), or maybe the bill of materials is different and there is a chip inline with the memory controller that's rated to a slower speed.
Can you grab the SPD of your 1 GB DIMMs to compare with these two at
https://68kmla.org/bb/threads/g4-mdd-ram-recognised-at-wrong-size.52427/post-592172
How do I get into OF from another machine without a serial port on the MDD?
Connect the MDD to your network via Ethernet. Boot into OS X to get it's DHCP assigned IP address. Boot into Open Firmware and use that IP address in the io command to change the input/output device of Open Firmware from keyboard/screen to telnet.
In the first post at
https://forums.macrumors.com/thread...l-work-in-a-beige-power-macintosh-g3.2303689/
search for telnet and click on the links to read posts discussing the topic.
example command:
" enet:telnet,192.168.0.121" io
Would you be able to share the top side as well?
The previous picture was the back side of the 166Mhz 820-1476-A board from a dual 1.25GHz G4 I purchased when it was brand new.
The front side of that board has been worked on, so I've attached a picture of the front side of another 166MHz 820-1476-A board in my possession. The "820-1476-A" model number can be seen near the bottom right corner of the picture.
Thank you for this.
