PowerBook 500 Series Powerbrick Replacment
Zhinü
Recently picked up a PowerPC 540C from a friend, who had cut off the original power brick and replaced it with a generic 16V supply. I’m currently looking at his work and I’m curious on if I could just attach both the battery wires and the main power wires to the same 16v supply.
I don’t think anyone has done it, only theorized about it, but I wanna check in with others to see. Has anyone attached the two wires to the same supply?
From what I understand, this would be dangerous. I think the battery charge side of the original PSU is intentionally limited to 1A.
Yeah I’ve been reading through your guys attempts on reviving the batteries. Good thing I didn’t wire it, guess I’m gonna have to find a 15v 1A brick and add that for charging the battery.
I'm gonna have to have a go at this sometime. I've got 2 full working 500 series, and a bit of a messy one, but only 1 PSU between them and I bet it's gonna go pop soon.
I’ve got two original power supplies that’ve been recapped and they seem to be holding up quite well.
I’ve got one I made and one original recapped. The recapped one was working fine for a while but then all of a sudden stopped working. I had resealed the plastic housing so need to open it at some point and see what happened inside.
