Quantum Hard Drives - which models can be (reasonably) fixed?
3lectr1cPPC
68LC040
Not sure whether to put this here or in the lounge...
Most of us know that old Quantum hard drives have rubber bumpers in the head assembly that go sticky and get the heads seized. Some Conner drives did as well, and I've recently heard that Toshiba drives are exhibiting the same problem now as well (laptop drives from the 90s specifically). Many drives can be revived by opening them up and either taping over the sticky rubber or replacing the bumper entirely. I have heard though that many Quantum drives put bumpers under the platters, which while possible to get to with special equipment, isn't possible to fix for most. Which models specifically do this though? It would be useful to have a list of which ones can be fixed, would be good for a wiki page or a page on my website. I recall one of them that did this was the ProDrive ELS or LPS models, can't remember which.
Share your experiences below!
I wouldn't be surprised if later LPS, Maverick, Fireball, etc, drives also have those bumpers. The LPS170S and 270S drives I have look like the ELS drives externally, whereas my LPS240S drive with the fried controller board is the older design without the under platter bumper.
I heard somewhere that the first gen Bigfoot drives have them. It wouldn’t surprise me if all of their drives did.
А simple solution to the problem of a sticky bumper on a Quantum ProDrive ELS:
Since it’s impossible to remove and put back the magnetic disk at home,
I glued a soft stop on the back of the voice coil,
which prevents the heads from touching the damaged bumper.
I doubt that this will be enough for a very long time, but it's better than a completely faulty hdd.
This disc has been working for the first time in this millennium :)
A little bit of a necropost, but basically: if it's a 160~800MB Quantum drive, it probably has a bumper hidden under the platters and as such is extremely difficult to repair. 9/10 difficulty, except for the single platter drives which are 8/10 (you don't have to keep multiple platters in sync, but the one platter still needs to come out).
More specifically, it's the ProDrive ELS/Maverick/Lightning and 2.5" models that do this. The LPS does not (available up to 230MB), nor do the Trailblazer or Fireball (or any of the enterprise-class drives like the Empire, Atlas, Grand Prix, etc.), so they just have the bumper(s) near the voice coil which makes the job a 4/10 at worst on most of them.
The Trailblazer (later rebranded to Fireball TM to ride the coattails of its more successful sibling) and most of the Fireballs I've seen use synthetic rubber and so far I haven't seen any that have become sticky (and I actually used the synthetic bumper from a dead Trailblazer to fix an older drive).
For those curious, I'd class the CDC/Imprimis-legacy Seagate drives (usually named for a bird or fish) as 10/10 difficulty. I've not seen anything more difficult to put new bumpers into as those.
I believe with the 2.5 drives that’s it’s only the original GoDrive that has the under platter bumper. The Daytona and Europa are only in the head mechanism.
I’ve done something similar to this today. I cut up a piece of old PCB and used kapton tape to get it up to the right thickness. Then I fixed it in place with a couple of small dots of superglue. Seems to work alright so far.
No need to get under the platters or even take off the lid more than half an inch with this fix.
The drive is an Apple branded 250GB unit, labelled Quantum ProDrive (no suffix). It reports as a Quantum Maverick 270S in SCSI Probe.
I've made a quick STL model of the insert shown above. If anyone has a Quantum Maverick with a sticky bumper issue, try printing this out and installing it, with a dab of glue to hold it in place.
The circular cutout faces down and the 'bulge' faces towards the platters.
I have an LPS I need to get going, but the screws are stripped on it. Any ideas as to what I could use on them that would be safe for a hard drive?
Oh that's pretty cool. I will have this printed off and can try it with my Quantum ProDrive LPS 250MB drive. It has a single park bumper under the platter like that one that this part would probably help fix. Head gets too close to the hub so I'm pretty sure it's got a expired rubber park bumper under the platter. :P
If you've confirmed the notch offset and stuff I'll have this printed out early June when I can afford to have a shop print this for me. :D
What printing material would be best for this part? I am thinking some type of Nylon? Also I plan on using double sided tape. Don't like the idea of putting any glue material inside the drive that could age and create contaminates at some unknown point in the future. Hopefully I can make it work with that. The double sided tape I have is pretty thin but won't know if the clearances are too tight for something like that or not. I will have wait till June to find out I guess. :P
It's important to note that the bumper is not a hard stop, but a soft element. I added a soft element (a fragment from a sticker on the end of a table tennis racket).
My hard drive still works!
Not sure if my design will fit an LPS. It definitely doesn’t fit an ELS.
These are photos of my drive. It seems very similar to someone else's who'd made their own via cut up PCB that you based your part off of:
Perhaps one addition you can make to your file is to add extenders to make it thicker in case the tolerances are off instead of making it a single unchange-able part?
