Power Macintosh G4 Disk Drive Benchmark Roundup
Here are the final results of my recent disk benchmarking efforts on a Power Macintosh G4 933 MHz Quicksilver. All tests were performed using QuickBench 4.0 under OSX 10.4.11. Transfer speeds are in megabytes per second. Results are separated by interface: IDE, SCSI, USB 2.0, and SATA.
Built-in IDE interface, on IDE channel 1 except where noted
Seagate Barracuda ATA IV 60GB ST360021A IDE 7200rpm (original hard disk)
transfer sizesequential readssequential writesrandom readsrandom writes
4KB
13​
10.1​
0.4​
1.1​
8KB
19.1​
24​
0.9​
2.3​
16KB
23.1​
24.4​
2​
3.6​
32KB
24.7​
24.9​
4​
6​
64KB
23.7​
26.8​
7.8​
8.9​
256KB
25​
26​
15.2​
14.8​
1024KB
26.8​
26​
22.9​
22.6​
Seagate Barracuda 40GB IDE 7200rpm ST340014A
4KB
17.8​
5.4​
0.7​
0.7​
16KB
34.7​
17.8​
2.8​
2.1​
64KB
45.5​
32.5​
9.7​
10.3​
256KB
51.1​
51.7​
17.7​
18.1​
1024KB
53.5​
52.8​
43.3​
43.3​
Seagate Barracuda 40GB IDE 7200rpm ST340014A on IDE channel 2
4KB
7.6​
3.2​
0.7​
0.7​
16KB
9.8​
6.8​
2.6​
1.7​
64KB
11.1​
9.9​
4.5​
7.2​
256KB
11.3​
11.5​
8.8​
11.5​
1024KB
12.1​
12.2​
11.2​
12.1​
IDE-to-SD adapter, paired with a PNY 16GB class 10 SD card
see adapter at https://www.amazon.com/dp/B07YFPX7JB
4KB
12.3​
0.2​
3.9​
0.3​
16KB
17.9​
1.4​
11.5​
1.1​
64KB
21.2​
4.3​
18.4​
3.4​
256KB
23.3​
9.9​
22.9​
9.6​
1024KB
24.1​
14.7​
23.9​
9.5​
IDE-to-SATA adapter, paired with a 750GB Crucial MX300 SSD
see adapter at https://www.ebay.com/itm/255483009090
4KB
20.4​
19.1​
14.4​
10.1​
16KB
37.1​
25.4​
29.7​
25.6​
64KB
38.2​
41.9​
42.8​
41.3​
256KB
52.6​
50.2​
51.5​
50.7​
1024KB
56.7​
53.9​
56.4​
54.5​
The primary IDE channel appears to max out at somewhere around 55 MB/sec. The secondary IDE channel where the optical drive is connected is much slower, and the same 40 GB hard drive was 2x to 4x slower when connected on the second channel. Don't put a drive on the second channel if you care about I/O performance.
Two different Seagate Barracuda 7200 rpm IDE drives had very different performance, with the 40GB drive being almost exactly 2x the performance of the 60GB drive for larger transfer sizes. For smaller reads they were comparable, and for smaller writes the 60GB drive was faster. It's almost like the 40GB drive has two platters working in parallel, and the 60GB drive has three platters in series, but the 60GB has more cache?
The IDE-to-SD was similar to the 60GB Barracuda for sequential reads, and better for small random reads, but the SD write performance ranged from bad to terrible. The IDE-to-SD also lagged the 40GB Barracuda in most situations.
The IDE-to-SATA adapter with SSD outperformed everything else in this category, although for large reads and writes the 40GB Barracuda nearly matched it.
SCSI interface, using Adaptec ASC-29160N PCI Controller Card (rated 160 MB per second)
Quantum Fireball 1.2GB SCSI
4KB
0.9​
0.1​
0.1​
0.1​
16KB
1.9​
0.5​
0.5​
0.6​
64KB
2.8​
0.9​
1.7​
0.9​
256KB
3.3​
1.9​
2.8​
1.9​
1024KB
3.2​
2.6​
3.5​
2.8​
ZuluSCSI with ADATA class 4 SD card
4KB
1.8​
0.2​
1.7​
0.1​
16KB
3.1​
0.5​
3.2​
0.1​
64KB
3.7​
0.6​
4​
0.2​
256KB
3.9​
0.7​
4​
0.2​
1024KB
3.9​
0.7​
4​
0.5​
ZuluSCSI with PNY class 10 SD card
4KB
2​
0.2​
2​
0.2​
16KB
5​
0.7​
4.6​
0.7​
64KB
7.2​
1.8​
7.1​
1.8​
256KB
7.9​
2.8​
7.9​
2.1​
1024KB
7.8​
3​
8​
1.9​
I included a SCSI controller card for interoperability with other computers' disks, not for a primary disk. The results were poor, but that probably says more about the particular drives I used rather than the SCSI interface itself. The SCSI controller claims up to 160 MB/sec performance but none of the tested drives could even reach 5 percent of that number.
The Quantum Fireball hard drive was worse than anything in the IDE category. The ZuluSCSI fared somewhat better, and reached its advertised max read speed of 8MB/sec when using a good-quality SD card, but it's clearly out of its depth here and is better-suited for older Macs. The choice of SD card does make a big difference, as the numbers show. The write performance of a class 4 SD card with ZuluSCSI was abysmal.
USB 2.0 interface, using GODSHARK PCI USB 2.0 controller card
see https://www.amazon.com/dp/B07S29C1S6
Samsung BAR 32GB USB Flash Drive rated 200MB/sec, formatted FAT32
4KB
1.2​
0.5​
1​
0.5​
16KB
5.1​
1.4​
4.2​
2.1​
64KB
12.4​
4.3​
10.8​
5.5​
256KB
17.8​
7.6​
16.4​
9.1​
1024KB
16.8​
8.3​
16.6​
9.8​
Samsung BAR 32GB USB Flash Drive rated 200MB/sec, formatted Mac OS Extended Journaled
4KB
1.1​
1​
1.1​
1​
16KB
4.6​
3.7​
4.5​
3.7​
64KB
11.4​
7.2​
11.2​
7.6​
256KB
16.7​
9​
16.4​
10.7​
1024KB
17.6​
16​
16.8​
10.6​
USB SD card reader with PNY 16GB class 10 SD card
4KB
1.2​
0.3​
1.2​
0.3​
16KB
5.1​
1.2​
5.1​
1.3​
64KB
12.2​
3.2​
8.6​
3​
256KB
17.6​
8.2​
15.4​
9.4​
1024KB
17​
13.7​
16.9​
9​
Next I tried some USB drives, with a USB 2.0 PCI controller card. USB 2.0 has a maximum theoretical speed of 480 Mbps or 60 MB/sec, and 30-40 MB/sec should be possible in the real world. Something in this configuration appears to be limiting speeds to about 17 MB/sec. It's interesting to note that FAT32 was about 2x slower to write than Mac OS Extended (Journaled), although read speeds were similar for both filesystems. The flash drive performed somewhat better than an SD card for small transfer sizes, though the difference disappeared for larger transfer sizes.
I experienced many strange problems when testing USB drives. One flash drive caused QuickBench to hang during testing, then after force-quitting, the drive couldn't be unmounted. I also tried three different external hard drives with built-in USB or USB-to-SATA adapters, but none of them worked. Two weren't recognized at all, and a third caused Disk Utility to hang while searching for disks. It was the same result with and without a powered hub. This might be a problem with OSX 10.4's handling of removable USB media, or an issue with the USB controller card.
I successfully tested an external USB DVD-ROM drive with the USB 2.0 interface. Although I didn't benchmark it, it was plenty fast enough for doing software installs, and could also be used to boot the computer.
SATA interface, using Adaptec 1210SA PCI SATA controller card
Western Digital Green 640GB SATA hard drive
4KB
20.3​
17.5​
0.4​
4.9​
16KB
51​
42​
1.6​
8.6​
64KB
80.8​
74​
6.5​
17.8​
256KB
84.9​
83.3​
24.2​
27.9​
1024KB
89.4​
87.2​
48.4​
47.5​
Crucial MX300 750GB SSD
4KB
21.8​
17.7​
11.4​
17.8​
16KB
51.7​
45​
36.3​
43.5​
64KB
74.1​
69.1​
64.5​
72.2​
256KB
88.5​
86.4​
79.7​
90.1​
1024KB
96.8​
95.7​
93.4​
97.5​
It was no surprise that a PCI SATA card provided the best results of all, with the SATA SSD reaching nearly 100 MB/sec! That's speedy, almost twice as fast as the same SSD when used with an IDE-to-SATA adapter. The SATA hard drive was also very fast for sequential reads and writes, almost matching the SSD, but couldn't keep up with the SSD for random reads and writes.
Unfortunately the SATA card is not plug-and-play. My Adaptec 1210SA card needed to have its EEPROM neutered by desoldering the chip's VCC pin, and then the card's flash memory had to be reprogrammed with new Mac-compatible firmware. The modified card works in my Quicksilver, but it causes problems when resuming from sleep, which appears to be a common complaint with many similar SATA cards.
TL,DNR summary: A SATA controller card is the fastest option, but can be problematic to set up. The $8 IDE-to-SATA adapter was also very good when paired with an SSD, and was easy to use. SD cards and flash drives are convenient but can't match the performance of real drives. The jury is still out on SCSI, but probably there's no reason to consider SCSI for a computer like this one since IDE and SATA are plenty fast.
Excel spreadsheet with raw data is attached.
A few more disk questions that could be interesting to explore:
- benchmarking the same drives under OS9 and OSX
- the performance effect of using different IDE drivers, such as HDT's versus Apple's
- performance differences between Mac OS Extended and Mac OS Extended Journaled
I recently read that the IDE-2-SD adapters you find online are actually CF-2-SD adapters repurposed as an IDE replacement.
The speed is limited to 25MB/s due to the SDHC protocol used by the FC1307A chipset on the board.
Alos SD card do wear fast also when used with intensive writes (i.e. logs, compiling large programs, etc.).
Not suited for anything above EIDE (ATA-3) I guess.
The ATA/133, U-DMA mode3 speed claimed on the product page is false advertising.
Thanks for that link to the Sintechi IDE-to-SD adapter. The desktop version described there looks identical to the one I used in my tests. They found a similar 25 MB max speed to mine.
You raise a really good point that I didn't touch on: regardless of speed, SD cards aren't really designed for frequent rewriting of data, and probably aren't the best choice for a main disk unless the OS knows it should try to minimize writes somehow.
With respect, this is a not-entirely-accurate oversimplification. Not all SD cards are created equally, and the outdated claim that "SD cards aren't really designed for frequent re-writing of data" is nowhere near an accurate statement, in 2023/2024. Modern SD cards, which have their own caches, wear-leveling (not all of them) highly-tuned NAND controllers, bear little resemblance internally to what we had 15 years ago . MTBF's for a cheap consumer-grade 32GB SD card are nowhere near the same as they are for pseudo-SLC and true Single-Level-Cell SD cards, from companies such as Delkin Devices and SwissBit.
Some SD cards, such as the non-consumer ones sold by Delkin Devices, even support SMART. Modern SD cards are lot more complicated than they were 20 years ago. The bottom line with SD cards is this...you get what you pay for. Since devices such as ZuluSCSI are entirely dependent upon the quality of the SD cards you choose to pair with them, it pays to not cheap out on an SD card, if you truly care about write longevity. Most hobbyists tend to only care about throughput, and are happy to ignore latency differences between SD cards, for instance. Other factors matter too.
For example, Digi-Key stocks ~75 different types and densities of higher-quality SD cards, which range in price from $50 for an 8GB SwissBit microSD card to $67 for a 2GB SLC SD card. A 512MB Swissbit SLC card can cost over $20, for instance. Companies like Delkin Devices manufacture both prosumer-grade SD cards, as well as industrial-grade SLC SD cards, and pseudo-SLC cards, for instance. Their industrial stuff is generally only available through electronics distributors such as Digi-Key. See https://www.delkin.com/products/industrial-sd/
Thanks for the info on SD cards. The first Raspberry Pi was released in February, 2012 and after selling millions of these SBC’s that use the micro SD card as primary storage - they’ve proven very reliable.
Reviving an older thread to understand how these benchmarks translate into reality…
I’m using a sata-pci card in an MDD macos 9, benchmarks 100mb/s+. I found real world file copy (single large file) closer to 35mb/s, lowering disk cache it’s now 55mb/s. I see this performance even if moving from ram disk to sata.
Is it expected file transfers in macos 9 are half the speed of benchmarking apps?
