Anyone thought to make a tool for this?
Curious about this. Has anyone thought to make a 3D printed tool for making taking the front faceplate off a Macintosh Performa/LC 520/550/575 chassis a little easier? I noticed something about how the clip works that would make this viable I think:
I posted about this as well here:
For some reason this forum has rather strict post limits? It kept saying my post was too long and couldn't be processed. I have not heard of a forum with such limited post size restrictions... That thread post I made represents the thread I intended to create here.
Anyways to keep long story short, the ridges on the clip design on the faceplate suggest Apple may have had a dedicated tool for this and the current method of prying with a large flat head screw driver is not really the best way to go. A 3D printed jig sized precisly to fit the slot and make use of those ridges to make the plastic clip move the exact distance it needs to for it to disengage is what should be best here especially with how brittle the plastics have become. (though my particular unit is in remarkably good condition despite a few small cracks near the screen bazel corners which were already present in the listing photos when I got this off eBay)
The generic car trim installer kits you see online tend to be my go to for prying open brittle plastic cases, using a couple of large flat spudgers along the seams.
Note the plastic was never strong even when new, I was once given a box of LC5xx faceplates which suggested Apple techs just replaced them over reusing.
Example of a trim removal kit or you could probably make your own
Oh neat I might bookmark that one. I wouldn't want to use it on in this case though. It would still require I do prying action at it while I pull the faceplate down. A dedicated tool should be a set and forget type of deal where you don't have to put pressure on it while working on pulling down the faceplate which is what should be possible with how they designed the clip on the faceplate. I might keep an eye out for any odd bits of random stuff I have laying around to see if they happen to be the right width and thickness to do what I want as a test but I'm pretty sure it would work. :D
I can no longer edit my original post to fix the broken image. Not sure why the image link broke. But these are the extra ramps present on the faceplate half of the clip. Mine aren't as damaged as this photo as I just grabbed this screenshot off a random YouTube video. (mine will eventually end up looking like this if I keep jamming random flat head screw drivers into it though. I suppose that ebay listing you linked to could help prevent that at least)
The idea is the tool would be a pretty basic rectangle in that is precisely fit to go into it and it just being inserted would be enough to disengage the clip.
On the subject of 3D printed parts, has anyone made a 3D printed bumper replacement for certain failing Quantum drives? I have a 250MB drive that won't init. After looking up this model I found it has a park bumper under the platter that has liquified. (unlike the other Quantum drives however it doesn't have 2 rubber bumpers in the voice coil assembly for the heads so only one bad part to worry about).
This drive came with a Macintosh Performa 575 I got off eBay a couple weeks ago. Kinda want to try and revive the drive so I can see what's on it.
:P
Also looking for replacement part for the worm gear used in the AppleCD 300 Plus drives. I have 2 of them and the gear has split on both. While one still works the other (the one that came with the 575) won't read CDs anymore. It's only a matter of time before the other one gives up the ghost as well. It's the little gear that moves the laser sled back and forth FYI. The gears for opening the tray are fine as well as the gear that's on the motor that drives the laser sled. It's the one attached to the spiral metal pole the laser sled sits on that needs replacing.
I made an insert for a Quantum Maverick:
You don’t need to remove platters or remove the melted bumper with this solution.
Cool. Is that part applicable for a Quantum ProDrive LPS (250MB capacity)?
Oh rather then using glue I could use double sided tape to hold it in place. I'd rather not have the glue degrade at some unknown point in the future and break off and get somewhere it shouldn't. :P
Would like to see how viable my idea for a jig for easy removable of Macintosh LC/Performa 5xx series all in ones would be. If anyone makes a STL, I will definitely get it printed and let you know how that goes. :P
