To the archival community,
I am initiating this thread to document the diagnostic baseline of a 6th Generation iPod Classic (160GB, Thick Black, Model A1238). This specimen has remained in my sole possession since its initial purchase in 2008 and has remained in an uncirculated state for nearly two decades.
The unit was originally acquired by myself in 2008 for use with an Audi A4. It remained connected to the factory interface inside the vehicle's glovebox for approximately 12 months. Since 2009, the device has been stored in a domestic environment. The original Audi-specific interface cable is included as part of the unit's history.
2. Physical Condition
Methodology: The unit has never been opened; the original factory seals and adhesives remain intact.
Front Housing: The front face and Click Wheel show no structural damage, cracks, or deep abrasions. Given the unit's age, there are faint, superficial micro-marks visible only under direct, high-intensity light—consistent with normal handling from its initial year of operation.
Backplate: The stainless steel backplate shows superficial scuffs and hairlines. These were incurred during the 12-month period the unit was connected to the Audi A4 interface in 2008. No polishing or surface restoration has been performed.
Interfaces: The headphone jack, hold switch, and 30-pin dock connector show minor surface micro-wear consistent with the aforementioned period of in-vehicle use.
3. Technical Data & Diagnostics
Tests conducted via the internal factory diagnostic menu (prior to the battery runtime test) indicate the following:
Total Power Hours: 12
HDD Start/Stops: 20
Retracts: 1
SMART Status: Reallocated sectors: 0 | Pending sectors: 0
Performance: Native HDD platter performance remains stable, with zero latency spikes or parity errors.
4. Battery Chemistry Verification
Methodology: Continuous playback of MP3 files | 50% volume | 50% brightness | 5s backlight interval.
Result: 35+ hours of continuous runtime before the 2% battery threshold.
5. Documentation Purpose
This data is being shared for archival reference. The unit serves as a data point for the longevity of the A1238 series in stock, unmodded condition. I welcome input from the community regarding similar long-term storage experiences with the 6th generation platform and the preservation of the original Toshiba MK1634GAL drives.
HDD Start/Stops: 20
Retracts: 1
