Preservation Report: Baseline Data for 160GB 6th Gen iPod Classic (A1238) - "Time Capsule" Specimen
K_Data
To the archival community,
I am initiating this thread to document the diagnostic baseline of a 6th Generation iPod Classic (160GB, Thick Black, Model A1238). This specimen has remained in my sole possession since its initial purchase in 2008 and has remained in an uncirculated state for nearly two decades.
The unit was originally acquired by myself in 2008 for use with an Audi A4. It remained connected to the factory interface inside the vehicle's glovebox for approximately 12 months. Since 2009, the device has been stored in a domestic environment. The original Audi-specific interface cable is included as part of the unit's history.
2. Physical Condition
Methodology: The unit has never been opened; the original factory seals and adhesives remain intact.
Front Housing: The front face and Click Wheel show no structural damage, cracks, or deep abrasions. Given the unit's age, there are faint, superficial micro-marks visible only under direct, high-intensity light—consistent with normal handling from its initial year of operation.
Backplate: The stainless steel backplate shows superficial scuffs and hairlines. These were incurred during the 12-month period the unit was connected to the Audi A4 interface in 2008. No polishing or surface restoration has been performed.
Interfaces: The headphone jack, hold switch, and 30-pin dock connector show minor surface micro-wear consistent with the aforementioned period of in-vehicle use.
20260518_101125.jpg20260518_223842.jpg20260518_101349.jpg20260518_101257.jpg20260518_065212.jpg20260518_131551.jpg20260518_100933.jpg20260518_131918.jpg20260518_160132.jpg20260518_101203.jpg
3. Technical Data & Diagnostics
Tests conducted via the internal factory diagnostic menu (prior to the battery runtime test) indicate the following:
Total Power Hours: 12
HDD Start/Stops: 20
Retracts: 1
SMART Status: Reallocated sectors: 0 | Pending sectors: 0
Performance: Native HDD platter performance remains stable, with zero latency spikes or parity errors.
4. Battery Chemistry Verification
Methodology: Continuous playback of MP3 files | 50% volume | 50% brightness | 5s backlight interval.
Result: 35+ hours of continuous runtime before the 2% battery threshold.
20260519_130625.jpg20260519_151034.jpg20260519_173408.jpg20260519_193517.jpg20260519_213531.jpg20260519_230529.jpg20260520_032925.jpg20260520_094631.jpg20260520_151315.jpg20260520_205652.jpgIMG-20260521-WA0001.jpg20260521_064256.jpg20260521_065135.jpg20260521_065147.jpg
5. Documentation Purpose
This data is being shared for archival reference. The unit serves as a data point for the longevity of the A1238 series in stock, unmodded condition. I welcome input from the community regarding similar long-term storage experiences with the 6th generation platform and the preservation of the original Toshiba MK1634GAL drives.
A great car – is that a B6 chassis? You should do an archival report for it as well.
Close, it was the model after the B6
Great car to drive, absolutely catastrophic at staying out of the garage though. If I had to make an archival report for that thing, I’d still be documenting dashboard warning lights five years from now.
Their absurdly overpriced OEM cable still works flawlessly though.😅
I thought they sorted out most of the issues with the B7. We still have a B6 Sedan from 2001. I managed to get on top of most of the persistent issues, the worst one was rainwater collecting in the driver’s footwell, which in turn created humidity which corroded the connector to the ECU.
Apparently not entirely. Mine drove wonderfully when it behaved, but over four years I had a battery recall, four separate limp mode episodes caused by a failed sensor , the entire left headlight unit had to be replaced, and at 149,000 km the dual-mass flywheel in the clutch gave up completely. That's what I remember just on the spot
So did this cable plug into the back of the Symphony/Concert entertainment system? How would you access it?
On mine I fitted a bluetooth module which uses the 'CDC' mode, normally reserved for a CD changer in the boot (but not really needed since the entertainment system has a 6-CD changer right there in the dash).
The input connector was inside the glovebox, but it was also designed in such a way that if you wanted to place the iPod in the spot intended for it right next to it, you had no choice but to bend the cable. So not exactly a great design. Making the cable just 10 cm longer would have solved it.
Yeah, I know about the input being in the glovebox, I was wondering where the cable connected on the other (output) end. And how you would tell the car to play the iPod through the car speakers.
You connected the iPod directly through the 30-pin connector. All the controls were handled through the car’s interface on the dashboard screen.
Ugh, the Audi Music Interface... because for some reason we just couldn't put a USB port in the car. I think some B7 head units supported AMI, but the feature was natively available in B8 MLB cars starting in 2009 for the A4 (2008 for the new A5). The point of having the cable (besides making Audi money) was that you could have a USB port, aux-in, or iPod interface all using the same plug. Bluetooth audio retrofits came later. Oh, and VW had a version of this too, but it was a different plug!
There were several revisions of the 30pin dock version of the cable. The "red" band was last revision that supported album artwork correctly with the iPhone and iPod Touch. When I switched to a lightning plug iPod nano, I eventually bought the AMI cable for it (since I had a MMI3G+ system that supported it), but the dock-to-lightning adapter worked fine in the car. The interface was NOT digital. While the interface allowed for control and browsing of the iPod, the actual audio was done via the dock connector's analog out to the stereo, so that meant the lightning cable needed a DAC too. This allowed for DRM protected music to play, but sucked since you couldn't use any of those 3rd party adapters that emulated iPods connected via USB.
When Audi introduced the new MIB2 radios (B9 A4) they finally switched to just providing USB ports to plug in iPhones and iPods, along with Apple CarPlay. My nano became a brick though since the newer radio didn't support the old original iPod communication protocol, only the one used by the iPhones and iPod Touch (Apple Accessory Protocol v2). Good thing it has Bluetooth streaming because that worked fine with that stereo.
Nowadays most folks with the older cars are buying those MMI retrofit systems that add a touch screen and Apple CarPlay/Android Auto making all this moot.
That’s a more detailed answer than just "30-pin cable" 😅
