Subtle video noise SE/30
Wondering if anyone has encountered this before. My SE/30 exhibits some subtle analogue video noise on cold boot, which seems to clear up shortly after its reached the desktop, or at least reduce to the point of rarely being noticeable. It's a rolling distortion that seems exacerbated by or synchronised to disk access (well, BlueSCSI). I've attached both a video and a frame for reference.
This is a recapped and cleaned logic board, albeit manually and not with an ultrasonic. The problem follows the logic board (I've tested with another SE/30 LB with this PSU and AB, and it does not happen with that board).
Things I've not yet tried, but will get to, is giving it another wash. Or probably just jumping to replacing the logic chips around UE8.
Will update once I've attempted these, but just curious if there are others with similar experience and/or suggestions.
I have seen exactly this issue on one of my SE/30s even after recapping the analog board. IME the rolling distortion (rows of pixels that jitter left and right, as in your videos) is a separate issue from the disk access interference.
I fixed the rolling distortion by reflowing the yoke connector on the AB, which had dry joints. Beforehand, like yours, mine would clear up after running for a while.
The disk access interference remains on both of my SE/30s, I haven’t found a way to reduce it.
Given my own experiences I’d like to persuade you that this is an analog board issue rather than a logic board one. I do understand you’ve tried different boards but I think you’ll find if you run another board for a while you’ll eventually see the same symptoms.
I'll second this. I spent forever troubleshooting an SE/30 board which had the same symptoms on 3 different analogue boards. I was convinced it was the logic board as they all worked fine with the other boards I had. As it turned out, all three of those analogue boards were causing the same problem.. but oddly only with that revision of SE/30 motherboard (the early one with the bodge wire).. just by complete coincidence I realised they all had the same issue with another one I acquired and was testing.
