Anyone know if this is a solder down CPU or just an odd CPU in a socket?
It's a QFP (soldered CPU) on an adapter into a PGA (pins) socket.
You see them occasionally. There is a listing for one somewhere in Europe ATM, not sure if this is the one. A 630 I think it was, same as what you're showing.
I'd keep it like that, it's quirky. Plus it's a 33MHz, so will certainly run at 40MHz, especially with a little heatsink.
Worst case you can desolder what's there and fit a socket.
But if you're super worried,I'd keep looking because that one is f-ing expensive.
I have one of these, came with a 630 board as well. It’s just a QFP to PGA adapter and you can remove it from the socket. I swapped a full 040 onto mine and run it in an LC475.
