Quadra 605 build log
I've had the same experience. I've wondered if it has something to do with the tolerances of the RAM and/or VRAM I'm using.
If the machine isn't crashing, just not going faster, then you've hit the limits of the PLL chip. When they run out of overhead they just stop increasing in frequency.
This is the stock MC88920? Replacing with MC88916 like this would be need go hit higher speeds?
Well, I got the clock chip in nicely (please ignore the fact that tinfoil is insufficient to protect the plastics perfectly in this area). I can actually clock to 45mhz now, but I get a bus error at 50mhz. Haven't investigated that too much (or cleaned the flux off yet).
You'll want to move R96 to the R95 position. It won't be stable without.
