Quadra 605 build log
I've had the same experience. I've wondered if it has something to do with the tolerances of the RAM and/or VRAM I'm using.
If the machine isn't crashing, just not going faster, then you've hit the limits of the PLL chip. When they run out of overhead they just stop increasing in frequency.
This is the stock MC88920? Replacing with MC88916 like this would be need go hit higher speeds?
Well, I got the clock chip in nicely (please ignore the fact that tinfoil is insufficient to protect the plastics perfectly in this area). I can actually clock to 45mhz now, but I get a bus error at 50mhz. Haven't investigated that too much (or cleaned the flux off yet).
You'll want to move R96 to the R95 position. It won't be stable without.
Similar to my experience. I need additional cooling on the CPU to stay stable at 50MHz. 45MHz is far more tolerant.
Is this mod strictly for the replacement PLL, or will it help stabilize software overclocking with the OEM chip as well?
It relates to the SCSI chip - the default setting is only intended for 25MHz. Even at 33MHz the other position is what is recommended.
Basically you'll get crashes if you do longer copies or decompress a file or use a scanner or whatever if you push the speed too far without moving the resistor from R96 to R95.
Assuming the CPU can do the speed anyway, but regardless, the resistor needs moving because it will be causing issues, even at speeds less than 50.
I still haven't figured out why I get a F00000001 sad mac about 1/3 of the time when this thing boots (even before clock change). I have some oversized caps on the SCSI power side, I'm wondering if they are back-powering the CPU or something, or it's something wrong with my bluescsi. I probably need to go and redo the recap with correct values, but it only happens with the bluescsi installed, so maybe this will help.
Thanks for the explanation! I didn't realize that needed to be done when using the software-only speedup. Time to put my LC475 back on the bench.
