Questions about Power Mac 6100 Maintenance and Preservation
Alright. So recently I got a few (new to me) vintage Macs. A Performa 6205CD (see my previous post to see how well that's going), a Beige G3 Desktop, and a PowerMac 6100 DOS compatible. All were, more or less, in decent cosmetic shape, but in testing, only the 6100 gave any real signs of life. Basically, it Bonged! Right away too. So, for now, there doesn't seem to be any issues with it.
I'm not too worried about the G3, as I only bought it for its case (I had another, the guts of which now live in the case of the new one). As for the 6205… well… that's being covered in another post (and I'm trying not to think about it right now).
The 6100, on the other hand, is from what I can tell, a far more… desirable? important? I don't know what the right word is. For me, the point is that it appears to be working and completely intact. And I'd like to keep it that way! (Although, I won't know the full extent of its functionality until the video adaptor arrives. To say nothing of the unobtanium that is the DOS Y-adaptor). Still, before I do anything rash, like recapping the PSU or motherboard, I want to get some advice on the best maintenance for these. I know this is a mid-90s era Mac so leaking Capacitors aren't out of the question, but this may very between models. So how reliable is the 6100's motherboard? What about the PSU? How about the plastics? From what I understand, the fact that both the case tabs are intact constitutes something of a minor miracle. So how can I keep them that way? Should I be taking a 'if it ain't broke' approach? Or should I be more proactive?
Side note: YES! I did remove the P-RAM battery. It was the first thing I did. The thing was dead, but thankfully, it hadn't leaked or exploded.
The motherboard, like all of its ilk needs to be recapped. The "if it ain't broke" advice doesn't apply since you can't tell until it is too late that caps are bad and have damaged something. I've recapped both of my boards (and my video card) and they are solid.
I have a couple of the PSU's and they seem to be fine (I haven't re-capped mine, but they seem to be better than the LC ones) and I monitor their activity periodically.
I have an opinion about the plastics, but there are others with an opposite opinion, so take it, or leave it.
1) I retr0brite mine, apply UV protectant and maintain them in a air-conditioned environment. No basements, attics or storage units.
2) I take them apart and put them together as little as possible - those clips are poorly designed for longevity and the interior support pieces are worse.
3) I keep spare parts (when possible). It's better to have them and not need them than the other way around.
Everything that is unobtanium comes out of hiding sooner or later, you just need to be patient and wait for your moment.
