Wireless mouse on Mac OS 9 is no longer an issue.
Hi guys. After several attempts, I’ve finally managed to resolve the wireless mouse issue on Mac OS 9. It’s not 100% perfect, but it works reliably.
From what I’ve discovered, even though newer wireless mouse receivers appear to be recognized correctly in System Profiler when plugged into a USB port, a closer look using USB debugger shows they are not actually being recognized properly.
The conclusion I reached, you need to “Refresh” or “Probe” your USB devices.
Inside Apple’s final release of the Mac OS USB DDK (version 1.5.9), there’s an app called USB Prober. This app is what will make your mouse function properly.
Requirements:
You’ll need a wired mouse at first, since you need to be able to click on things. Also, the wireless mouse USB receiver must be plugged into the USB port.
Steps:
1. Place USB Prober inside the Startup Items folder within your System Folder.
2. Launch USB Prober.
3. Close any windows that pop up. Then go to the top Apple menu bar, click Windows > USB Bus Probe, and open the window titled USB Bus Devices.
4. At this point, your wireless mouse should start working properly. However...
5. Important: Never close the USB Bus Devices window manually. You must exit USB Prober using File > Quit from the Apple menu bar.
Why this is necessary is...
If you close the USB Bus Devices window and later reboot, USB Prober will launch again but the USB Bus Devices window won’t open automatically. This specific window is critical because it’s what triggers USB devices to be probed.
After startup or reboot, once USB Prober runs and the USB Bus Devices window appears, you should manually exit using File > Quit. (Do not close the window directly.)
*** By the way, I think it would be good to write an AppleScript that automatically quits the USB Prober app after booting, but I'm not sure if that's even possible, and I'm unfamiliar with this area.
It also works well with USB Overdrive. I’ve set it up to use right-click and reversed scrolling direction, just like in the current version of macOS.
I've also attached the 'USB Prober' app.
Requirements:
Steps:
Good afternoon
After several attempts on Mac OS 9 and on modern Mac OS X, I've been unable to properly un-zip the "USB Prober.zip" file. It comes out as a PowerPC app package on modern OSX, but none of the files can be run on OS9. It seems to be an OSX app?
Where did you get the USB DDK from which this file came? Or could you re-upload? Thanks
I’m using a Logitech Bolt receiver on a MDD under Mac OS 9.2.2 and it works fine with my MX Master 3s.
Funnily enough installing USB Overdrive caused the mouse to stop working.
:LOL:
All my Logitech pointing devices do this thing where they perpetually drift in one direction. I have four devices that do it, two combined keyboards and trackpads, one mouse and one stand alone trackpad.
Installing USB Overdrive has always been how I fix it. It's on my bootstrap quickstart CD for that reason.
Just installing USB Overdrive has always solved issues for me? No need for scripts or manually probing things.
I'm actually looking for potential solutions to the Mac Mini G4 mouse freezing issue.
USB Overdrive is impressive; Logitech MouseWare does the job for me, even works with newer wired logitech mice.
