Just bought some ANS locks and keys:
I snagged all of them. I'll have extras, but my goal is to rebuild a Quadra 950 lock which is missing they key since these use the same keyways.
I'll have extras and you know how much I paid, so if anyone wants one, send me a message. I should have them in a week or so.. give or take.
How are you planning to rebuild the 950 lock? I have a 950 but with the wrong key, so I’d love to know how you accomplish this and see if I can replicate it!
So, the long and short is this. The lock is assembled at the factory and cannot be re-keyed without destroying it.
Post a picture of the key you have. I *might* be able to get another 900 series lock without a key and I know what the one it uses looks like. Also, post the key number. It's on a tag connected to the wire on the lock.
I find that re-keying the quadra locks is pretty trivial- at the end of the day, we're not super-worried about security, pull the core and then just find a single pin or two from your starting lock that matches the donor key, and reassemble- you can leave out the other pins.
How do you get them apart? The AWS locks are all metal and there's no obvious way. On the manufacturer web site, they say they can't be rekeyed.
