I have a couple hundred drives I need to archive. SCSI and IDE. What would be your ideal setup to accomplish this?
shu82
Lets say I have access to almost any platform/peripheral and a bluescsi v2. SCSI ones are the challenge really. What would be the optimal setup to have the best success? I was thinking an early or mid PPC tower. But I do have an old world g3 as well, scsi cards, and drive enclosures. How would you do it? Any software preference?
with scsi, i'd use a Zulu-compatible scsi emulator that has initiator mode. that will image the drives well... all you need is two drive enclosures and appropriate cabling.
for ide, i'd get an ide/usb adapter and image with a modern computer.
For the SCSI drives you can use the BlueSCSI v2 in Initiator Mode. It'll copy the disks once you connect the drive to it without the need of a Mac.
That was my first thought to do. But, I was wondering if a direct install into a working old world tower would still be the preferred method. Then I also have a sata card with an ssd. I was wondering if going that far would cause complications vs staying on the scsi chain.
