NuBusFPGA: HDMI on NuBus Macs
The problem is only the size of the board - the bigger they are, the more expensive... you don't want to build something the size of a NuBus board if you can avoid it. In particular with more layers and/or more sophisticated processing.
hehe, perfect timing: IIsiA7 Mini. My first design with onboard FPGA. However, it's 6 layers and double-sided, so even more expensive per area (the savings come from not needing the daughterboard!).
The IIsiA7 Mini is not that expensive. The true cost isn't in building the hardware, it's in supporting it - I just don't have the time... Doing a couple dozens at a time, the cost would likely be below 100€ per unit (depending on the FPGA, and how badly the supply chains are f*ck*d by AI madness and the war in the middle east...).
The only board I've given up on because of cost is the QuadraFPGA; it's the most useful (as Quadra have the horsepower to actually exploit the larger screen and better audio), but the connectors are too costly. Not per unit, but the only source left is Mouser (or similar) with a MOQ of 200 at ~13€... 2600€ for a large box of connectors is a bit much for me. At one point there was some NOS (new old stock) left, but all the wells appear to have run dry by now :-(
I'd definitely be interested in something like that. Of course, I don't have a IIsi to put it in, but if that could be put on a NuBus card...oo la la. Is a 7" NuBus board really that much more expensive, even at six layers?
As for the QuadraFPGA, is the connector you're referring to that bizarre PDS slot that the Quadras have? I have ONE card that plugs into that, and that's the PPC 601 card, currently in my Quadra 650. My bizarro-Q700 and my WGS80 have the same slot, currently unpopulated.
Somewhat more expensive. And you need a different connector than the one used in the originals NuBusFPGA V1.0 and V1.2, as those are too low-riding on the PCB for the cable to fit in the slot adequately. An internal connector, small cable, and a proper 3D printed backplate would be a cheaper and easier solution. From the outside, you couldn't tell the difference.
I'm not planning to do a NuBus version with integrated FPGA - the IIsiA7 Mini was my attempt at integrating FPGA and DDR2 on the PCB itself. for learning.
Yes. Using the '040 PDS makes access by the CPU to the framebuffer much faster. there's some benchmarks in the official thread.
I might have a spare Nubus carrier for you, it is of the v1.2 but with a modified hdmi connector so the connector does not hit the back plane. Send me a DM and we can chat about. I have all of the carriers :) and can provide you a preflashed ready to use card if you want.
DM sent. I'm in Norway for a few more weeks, could potentially stop by.
