Hello all! Just want to see if some more experienced people have some ideas of where to look or experience with any of this.
So, I have a Mac SE/30 which sat for a bit, I changed the PRAM battery, and now the computer doesn't work. I recapped the board in 2016, so I know it's been awhile. But, I examined my work from being inexperienced. There was some mess that needed to be cleaned, but I cleaned and touched up the board. It has 20mb of RAM in it currently, but any RAM configuration will cause issues. Below is the list of issues
Basically, what I'd like to know is if anyone has any idea where I might look next for errors, traces, corrosion....etc. Or any diagnostics I can do. There is always of course the slight worry that I'd made the BlueSCSI wrong and it nuked the SCSI controller chip, but...being that it can see it and read from it, I'm not sure about that. Just don't want to lose one of my favorite machines!
Thanks!
- The internal SCSI drive cannot be seen anymore. I hear it trying to be accessed, but only for a brief moment before it returns to the question mark screen looking for an OS.
- An external device such as a BlueSCSI will have a happy mac for just a moment, then back to the ? screen, no matter what image or SD card I use,
- I *can* boot into System 6.0.8 on a floppy disk. The internal drive still isn't seen, but the external one, if available, can be. Any further issues will assume I've booted into 6.0.8 on floppy disk
- Any attempt to write to external SCSI will fail. Write error.
- Any attempt to run a program from any source, disk, floppy disk, external.....crashes the system immediately. Except for small programs like the control panel or calculator.I can also successfully format a disk, both floppy and external SCSI.
- When crashing, the errors are all over the place. "Bus Error" "Address Error" "Coprocessor Not Installed" "Illegal Instruction" are the main ones I see. External SCSI attached generally causes bus and address errors. Without it, I get illegal instruction or coprocessor not installed for most things.
- Maybe important: When I last ran the system 6 months ago, it did this until it just....started working normally again.
Thanks!
