SevenTTY — local shell + terminal + SSH for classic Mac OS
I finally fixed the FTP bug, and so i felt good about cutting another release. I also added in > / >> redirection for various commands too! Wget with auto-file-typing and TLS1.2 support (TLS did add some size to the binary, but memory usage still decent due to other optimizations). Also a proper scrollbar, lots of other goodies.
SevenTTY v1.2.0
The biggest release yet — SCP and FTP file transfer, 34 new shell commands, flicker-free rendering, output redirection, and major memory and performance improvements.
New Features​
  • SCP file transfer — download and upload files over SSH with scp command. Supports password and key auth, glob patterns for batch upload (scp *.txt user@host:~), transfer progress display
  • FTP client — full FTP client with ftp get/put/ls subcommands and wget ftp:// integration. PASV mode, progress bar, glob uploads, password prompt
  • Output redirection — shell commands and nc now support > file (truncate) and >> file (append) to redirect output to local files
  • 34 new shell commands:
    • Checksums: md5sum, sha1sum, sha256sum, sha512sum, crc32
    • Text processing: grep (-ivnc), head, tail, wc (-lwc), nl, cut (-d -f), fold (-w), rev, rot13, strings (-n)
    • File utilities: hexdump, xxd (-r), cmp, ln -s (creates real Mac aliases), readlink, realpath, which, basename, dirname
    • Line ending converters: dos2unix, unix2dos, mac2unix, unix2mac
    • System: uptime, cal, hostname, history, sleep, seq
  • fixtype command — auto-set Mac type/creator codes from file extension, with glob and multi-file support
  • Vertical scrollbar — proper Mac scrollbar control with arrow, page, and thumb tracking
  • Finder alias resolution — local shell commands transparently resolve Finder aliases (cd, cat, open, ls, cp, head, tail, etc.), including in glob expansion and tab completion
Improvements​
  • GWorld offscreen row buffer — terminal rows are composed offscreen and blitted atomically via CopyBits, eliminating erase-then-draw flicker
  • Dirty row tracking — only changed rows are redrawn (10-24x fewer cells drawn for cursor blink, single-char echo, etc.)
  • GWorld depth matching — uses screen depth instead of fixed 32-bit, avoiding expensive depth conversion on 8-bit displays
  • Memory diet — scrollback and shell history moved from embedded arrays to heap-allocated pointers (saves ~320KB from globals). Thread stacks reduced. Partition size reverted to 2MB, runs on 4MB Macs
  • Mac Roman to UTF-8 conversion — local shell output correctly converts Mac Roman high bytes to UTF-8 for proper glyph rendering in vterm
  • ANSI.SYS compatibility — translates ESC[s/u (cursor save/restore) to DEC VT sequences for correct BBS ANSI art display
  • wget threaded worker — downloads run in a cooperative thread (no more UI freeze). Inline progress, download speed on completion, -n flag to suppress progress
  • wget improvements — TLS handshake timeout, redirect handling (scheme-relative, absolute, bare relative), content-length validation
  • rm glob support — rm *.bin with -i interactive confirm
  • Scroll shortcuts — Cmd+Up/Down scrolls one line, Shift+PageUp/Down scrolls half page
  • Paginated help — help output now shows --more-- prompt
  • cal improvements — full year view (cal 2026) with 3 months per row, today highlighted in reverse video
Bug Fixes​
  • FTP multiline response fix — FTP connections no longer hang on servers that send multiline 230 responses (e.g., ftp.gnu.org). Root cause: null-termination of parsed line corrupted the first byte of the next buffered line
  • FTP connection refused handling — properly handle kOTLookErr/T_DISCONNECT
  • OT send deadlock fix — kOTFlowErr now yields instead of falling through as fatal. Fixes busy-loop deadlock during sustained writes (SCP upload)
  • SCP upload stall fix — broken int64 formatting on 68K fixed with manual uint64-to-decimal in libssh2 fork
  • SCP path fixes — filenames with spaces, ~ as remote directory, basename from Mac colon paths, buffer overflow guard
  • Symbol font fixes — font family ID moved to 29183 to avoid conflicts with system fonts. Resources pinned with HNoPurge, Font Manager cache primed at startup
  • DrawGrowIcon clipped — prevents horizontal line from cutting across terminal content
  • Memory leak fix — scp_auth_prompt prefs restoration
I wonder how many commands it has now compared to Busybox or Toybox
Those are the direct inspiration for this, definitely a lot of them now. It also takes the "One binary that does it all" approach. That's about all they have in common though, as it's not sharing any code with those projects, and it's not actually trying to create the required unix subsystem that those would need (that's more the macrelix approach, actually.) This is meant to be more of a mac-native equivalency shell, as if classic mac just had a shell of it's own, and the various command-equivalents are the shell "built-ins."
I think the main ones i skipped are things that wouldn't make sense until I add some notion of piping, like sort/uniq. The "one-binary" approach means I was able to build a lot of this functionality without said unix subsystem, but that also means things like native pipes just aren't a thing. Though, after getting the "> / >>" redirection working, I've got some ideas on how a pipe-equivalent might work. It's definitely on my mind.
Few other things I've been thinking of doing, like a proper interactive shell for FTP/SFTP. SCP is now supported though, which covers a lot.
thx claude...
I've already established how I feel about this, but I will repeat in somewhat different (and hopefully not contradictory) terms: I wouldn't use AI for anything myself, but so long as @Xero is honest and transparent about how he uses Claude (or whatever his chatbot of choice is), what he's using it for, and what he does to make it work (versus posting worthless slop without any disclosure), I really couldn't care less if he uses it or not. It's a tool like any other, and if used properly and appropriately, it can be a boon for hobbyists such as Xero, because a single person can now use it to do things that previously required hiring a small team of people (not that I advocate that companies adopt it en masse as they are, because it puts the people behind those teams out of work, and it puts ordinary users at risk due to the innumerable security and ethics concerns, none of which we need to get into detail about here).
That said, while I haven't used it myself, SevenTTY seems to be a decent software package that apparently works as advertised, and it represents a genuine contribution to the vintage Mac hobby.
All this is to say: There is no reason to keep trolling Xero. Let it go!
c
It tends to be something like, Claude as my coder, Codex for code review, myself as QA/UI/UX tester, haha.
You know what's really crazy, like every other week there will be some story on reddit where someone posts about these stories of "3 AI users replaced my whole team" or some such nonsense - it's almost always proven to be someone karma farming. Every, damn, time.
The real version of this seems to be companies just blindly laying people off without actual replacement (AI or otherwise), then asking other people to put in longer hours and/or otherwise regretting the decision in short order. Or it's just an excuse to cut people that were already under-performing. And that's exactly what it is - an excuse, but I am not convinced it's actually directly because of it. From the real world studies that are coming out now, the actual people being effected, is those with little work experience, the juniors just starting out, college grads, etc. It's raising the bar for entry.
Before AI was the excuse, it was "outsourcing", or "recession", or "cloud migration", then during covid, that was the excuse, then 2022-2023 was the "over-hiring correction" after the zero interest loans dried up. And now it's "AI will replace you". The biggest thing to remember is, they're always going to make excuses for these decisions, because those excuses sound better to shareholders than "upper management didn't know WTF they were doing", it's all just a game of CYA.
@Xero I won't go into too many details (because politics), but I agree with you.
The thing that's most disappointing to me is the higher bar to get in.
Every upper level job that I know of requires, in addition to a college degree, some kind of experience, which is usually gained at an entry level position of some sort, but how can anyone ever gain that experience if all the entry level positions are taken away? It unfairly puts recent college graduates and other newcomers to the industry in a sort of Catch-22: they need experience to get a job, but they need to get a job to gain that experience.
This increasingly dismal treatment and seemingly deliberate demoralization of workers by most tech corporations has all but turned me off to getting into the computer industry at all. An industry that I used to enjoy and always fantasied working in.
To paraphrase a line of a favorite song of mine: I'd rather drive a truck than deal with the modern industry.
c
c
Funny thing about that line: long haul trucking was one of the first industries impacted by AI.
But yeah; the barrier to entry has always been there. The problem (as I see it) is that you graduate with your shiny CS degree, and are looking to do something transformative in the computer design or software architecture field -- only to find that unless you have the money and connections to start your own company, you need minimum 4 years of on the job experience to get your foot in the door. As a CS grad, most people are looking at something directly related to their specialty that can pay off their student loans.
The reality is that to get started, you need to find work in a company that does something non-tech-related, likely associated with a secondary skill you have. Because THOSE companies need tech-minded people too. And you can quickly transition there from a "we hired this kid to make a new web portal for our toolcrib management" to "oh wow, this guy knows his stuff! Let's put him in charge of DESIGNING the new company-wide asset management system!" and before you know it, you've helped the company modernize their assembly line and your job title is "Solutions Architect", and 5-8 years have passed.
NOW you've got the record and the experience to skip all those entry level jobs and get hired for something more interesting.
To be honest, a job like that might be more fulfilling in the long run. If you keep on top of your career development you've more chance of ending up in a real senior technical role and you get to work on end to end implementations. If you do well you'll end up building your own team.
Although realise that any bodges you make on day one will be there, niggling at you for your whole career because it will never be quite the time to replace that critical system 😆
That was one thing I really appreciated when I eventually changed companies :D I got to deal with other people's bodges and left mine to other people to clean up!
c
Haha, or the Office space version of that - time to go do construction work, lmfao. I've been in this industry for so long now that it's hard to imagine doing anything else, but I also don't really fit in most of the boxes you mentioned, never had a formal education, etc. It's never been the blocker though, you just find like-minded self-taught people that hire you. Damned if I ever land a job in academia though, LOL.
i guess i'm the oddball out there, since I kinda skipped a few of those steps. I will say that the younger people with those degrees are the ones I've talked to most afraid of AI, there's a certain attachment to the process they were taught that people seem to clutch onto. For me, coding was just a means to an end - how do I make this system work - was more my concern, etc. I didn't really care how I got there, none the less the "theoretical" or "technically correct" way. I think that's why I get along with this stuff so well.
Hah! Just have to do it perfectly the first time, every time! I kid, I kid...I used to have a lot more opinions about doing things certain ways, simple solutions, worse is better, etc, and while AI does kill a certain part of that opinionated-ness, most of those core principals still apply.
LOL. I've seen some crazy bad stuff, but also crazy cool stuff at previous jobs, like a guy who wrote a calculus-based predictive disk check. Of course, he'd already left by the time I started, but man, I definitely wanted to meet that guy. Now, AI does the calculus for me, LMFAO (and that's not even a joke...) The irony is, I bet that guy could have claimed his disk check was "machine learning", or "AI", depending on the year, and no one would have batted an eye. Now you can use bernoulli principal casually for a visual effect on a website like it's nothing, it's not just for the box anymore! Hah!
I tried running this on an LCII - the terminal window flickers every second or so, and typing is very slow as well. It appears to be redrawing the window contents every second instead of waiting for changes. This was on System 7.1. Still, interesting progress being made.
Not sure if improvements can be made, but keep in mind that the LC II is almost the slowest colour Mac.
I suspect that part of the reason you see it like that is because the software uses an off screen buffer and then blits it to the screen. This means that you don't see any localised updates. This gives a better overall look to updates, but might be a bit much for a 16MHz host with only 16bit RAM.
I mean, to be honest, wow, it works on an LC II 😆
It does bring up an interesting point re: display efficiency. Presumably it would be a bit more performant if the blitting was suppressed when you knew for a fact that no changes had taken place. This reminds me of an old timer’s opinion I read once, to the effect that you really get a feel for how good someone’s screen-update code is if you’re seeing it on a terminal at 300 bps. :¬)
Or under Windows 11 😆
Due to some nonsense the other week with updates or virus checks, it took literally five minutes to draw the save dialogue box in Acrobat on my work machine. Interestingly there was an unused field drawn in at one point, so there must be an empty text box in the "do you want to save" dialogue.
Monochrome and color terms are basically the same speed on the LCII. Maybe the blinking cursor is causing more screen updates? I don't see an option to disable the blink.
hmm interesting dilemma. i'm definitely trying to make this thing faster still, but my last round was focused on getting SCP/FTP/wget while keeping memory footprint down. It's still fairly slow on my quadra 700 too, especially with responsiveness when typing, so I'm thinking next release will need to focus on more speed improvements. A cursor style/blink disable setting is probably fairly trivial, but I need to also dig into if it's trying to redraw everything or just that row. I was pretty sure I had some bugs around that fixed, but the LCII might be exposing other issues. Will try to look into this shortly.
I definitely did some tweaks around when the updates take place, but I also don't have an LCII to test with, either, I can only imagine it's worse than the quadra by a fair amount. I've been a bit busy the past few weeks, so a lot of my testing was in QEMU, which is far too fast to represent anything realistic. The quadra 700 is substantially slower than any of my PPC machines though, so it's still a better test than nothing, and I did eliminate the flicker i was seeing on the quadra, so it's interesting that it's still showing up on older machines.
If I ever needed any excuses to buy more old macs though, lmfao....I do have some nostalgia for the old LC though, they were one of the ones I used to use back in the day.
For now, one thing you might try is if you turn off the cache in the 040 cache control panel, it will significantly slow down your Q700 and make it behave like a much slower computer. Just remember to turn it back on 😆
