Upgrading my G4 MDD with a SONNET Encore/Crescendo MDX G4 Duet 1.8GHz Dual CPU Upgrade
Irinikus
I've finally managed to get my hands on one of the very rare SONNET CPU upgrades for the PowerMac G4 Mirror Doors: (I purchased this one from a seller in Japan)
This is what the machine originally looked like on the inside: (It was originally a single 1.25GHz Machine with Radeon 9000 Graphics)
This is what it looks like now: (It's now a dual 1.83GHz machine with a Radeon 9800 Pro Mac Edition and a Belkin 5-port USB 2 PCI card, giving it four external USB 2 ports.)
Here's how OSX sees the system:
The Blender Test Result for this one are out:
Here's where it fits in with the other G4's I've tested: (I still have to test my MDD Dual 1.42GHz machine at some point!)
Here's where it fits in with all of the other systems I've tested:
Not too shabby! (It's performance is pretty much exactly where it's supposed to be.)
I’ve added an extra fan which blows directly onto the CPU module:
I ran a Blender test to stress the CPU with Temperature Monitor running, and the highest temperature it reached was: 63'8 Degrees C (The current ambient temperature's in the region of 32 to 33 degrees C.)
It just beat it's last Blender score, as it did it in 1 Minute and 41 seconds!
I'm not quite finished with this system yet, as I still need to upgrade the drives to SATA SSD's (IDE to SATA converters), give it its full complement of DDR 333 RAM (2GB), install an Air Port wireless card which is compatible with modern WI-FI routers and install a 3-port FireWire 800 PCI card.
Well, that is a very fancy processor. I don't have any G4s anywhere near that clock speed. I did find a Radeon 9800 at one point, but it has graphics artifacts, so that is a project for some point in the future. I suspect it got hot and a VRAM chip partially detached at some point in its past.
Which direction is the heatsink fan blowing, and which direction is your new big fan blowing? Make sure they're working together.
Awesome! I do have exact same boxed CPU and its not even opened either, bought it from Japan as well but very cheap at that time back in 2016 I think it was.
Tempted to sell or install in my G4 MDD...
Cheers
A
The fans are blowing in the same direction.
Cheers
A
Cool! :) I'd hang on to it if I were you.
Nice write-up and cool benchmark graphs!
Fun to see a comparison with a variety of hardware too
My Sawtooth G4 has a single 1.6GHz Sonnet upgrade
Sweet setup! Does it still boot into OS9 after the upgrade?
I've got a dual 1.42 GHz MDD with a Radeon 9250 for OS9 gaming and a Radeon 9800 Pro for OS X gaming. I've been playing some Dungeon Siege, CoD, and CoD United Offensive on it recently.
I haven't tried it as yet, but it apparently should work. (I'll maybe take a look at trying it later on)
I have another rather interesting machine which serves as my OS9 machine. (OS9 runs like a champ on this machine.)
I found the Sonnet dual 1.8 to be a very satisfying upgrade from the 1.42 in my FW400 MDD G4 that originally was a dual 1.25GHz. Between the time I bought it and the time it arrived, I’d read that cache differences make the dual 1.42GHz cpu the better choice. Not my experience.
I didn’t like the sound of the Sonnet fan, so replaced its heatsink with the aluminum heatsink from the dual 1.25 cpu (the copper heatsink from dual 1.42 was incompatible). The Sonnet cpu runs so much cooler than the stock cpu, that the G4’s 120mm x 38mm fan stays pretty quiet most of the time.
The cache on the Dual 1.8GHz's on-die, and that makes a huge difference, even though it's smaller.
If I managed to get this cheaply, then I'd consider modding it, but considering what I paid, I don't want to touch it. (As a collectable part, it is what it is.)
I love this because it's such a great example of the new and old world stuff mixed together. It was a weird and exciting time.
I do have G4 MDD - originally its FW400 model, with FW800 1.4ghz CPU & Copper Heatsink on it, with Sonnet SATA card with SSD attached to it - its a quite quick mac - which is why I hadn't done Sonnet upgrade.
Yes it does boot into OS9 with Sonnet from what I know.
Cheers
AP
Cheers
AP
I also have this Firewire 800 Dual 1.42GHz machine which I'll have to put up against the Dual 1.8GHz at some point, just to see if the increase in MHz gives a linear increase in performance between these two systems.
As there's a large difference in cache size between to two CPU modules.
The MDD now has its full complement of RAM: (2GB)
I've purchased one of these from Amazon in the US, so it will take a few weeks to get here: (StarTech.com port 2.5 in, 3.5 in IDE to SATA Converter, Hard Drive Adapter)
To replace the spinning rust with an SSD.
Others have tested this so I don't need to: A SATA SSD connected to the ATA 100 Drive controller using one of these adapters is just as fast as a SONNET Tempo PCI SATA card linked to an SSD via a SATA cable in one of these machines. (The SONNET Tempo would just result in a messy build, as the SATA cable now needs to be routed through the case.)
The nice thing is that these feature MARVELL controller chips and not simple generics.
Here's the current system disk's speed as a baseline for the future comparison:
It's not great, so the SSD should boost things quite a bit!
I've ordered one of these cool SSD brackets for the MDD, It will allow the StarTech adapter to fit snugly into the system: (Orico 2.5" to 3.5" HDD/SSD Mounting Bracket Adapter.)
You will find having PCI SATA card way much faster than internal bus. - you could find one and flash it.
Cheers
Here’s a video showing the comparison:
I do have a SONNET Tempo PCI SATA card in my G3 B&W fitted with a 1GHz SONNET G4 upgrade.
