Hello, I have my LC 575 (or is this a 550 or 520?) logic board that I use for my Color Classic but it's been in the garage for some time and has collected a bit of dust and stuff.
What would you recommend for cleaning this before I stick it into my Color Classic so that I don't short out something that might have formed on the board.
Do I remove the battery and then bathe the board it in isopropyl alcohol? There are no signs of leakage that I can see. Or is there? I'm not sure, can you tell me if the closeup photos like R117 are leakages the red bubble, or is this normal? I ask because some of the other resistors like R138 seem to have a red dot next to the resistor, is this something starting to leak or are these nothing to worry about?
Cheers, @SkippRnim
Cheers, @SkippRnim
