Fun with userspace AppleTalk
I've been really wanting to write software to speak AppleTalk to my various LocalTalk (and sometimes EtherTalk) systems. I've found the C API for Netatalk isn't super pleasant, at least coming from the Rust world with async/await everywhere.
This is a little milestone from my own fully userspace Rust AppleTalk stack that provides a no_std (i.e suitable for embedding on micros) parser and encoder for every AppleTalk packet type, and a Linux/Mac/Windows stack that uses raw sockets so has no reliance on the kernel itself to build on top of it. No code reuse from Netatalk either, all built with Rust + Tokio in mind. It exposes high level async APIs with Tokio for all of the protocols as well, so to look up a LaserWriter and print to it via NBP is trivial.
Not meant to be a super serious project, but the eventual goal is to have most all the usual functionality that Netatalk provides working, including AFP so I can transfer files easily from my Linux machine to any of the older Macs. Thought I'd post it here in case there was any other Rust interest :).
Picture is from my userspace stack printing the Rust logo from my Linux tablet, with LLAP, NBP, DDP, ATP and PAP all working in harmony :)
Wow! I‘d like to see more! 😃 I‘ve also been writing an Embedded/Userspace AppleTalk stack for several years now but progress has slowed down substantially in recent times.
If you're up for staring at Rust code I'd love more eyes on it. I hope to publish it soon on GitHub once the API is a little less crazy hah. But so far it appears to be working pretty well - I've got a handful of external demo programs made for it, like an AEP echo'er, NBP lookups, the above PAP printer, and AFP is at the point where it tries to start manipulating files.
Very much a toy project of course. My day job is writing userspace network stuff so I've enjoyed trying out some new concepts here.
Ooh, this is Relevant To My Interests. I tried something similar a while back, creating a collection of programs that together amounted to a userspace inetd for AppleTalk, but got stuck somewhere in PAP-land... I'm interested in having a peek at the source whenever you release it.
Hah I think you can guess why I was excited to get that Pi hat then. And of course! Sounds like our goals are/were pretty much the same. I’ve found a few LocalTalk quirks I’m sure I’ll need to ask you about too
OK, just to remind me about Netatalk. Let's say I have my MacMini Raspberry PI 3 WIFI and my PowerBook 1400c (+AirTalk). Is Netatalk the right way to get me to:
  1. PB1400c <---[LocalTalkCable]---> Serial: PI3 ?
  2. PB1400c <--->AirTalk )))) (((((Wifi <---> PI3?
  3. PB1400c <--->AirTalk )))) (((((Wifi <---> Mac Mini?
  4. PB1400c <---[LocalTalkCable]---> Serial: PI3 {<--->miniVMac} ?
  5. PB1400c <--->AirTalk )))) (((((Wifi <---> Mac Mini? {<--->miniVMac} ?
you probably want tashrouter
netatalk is mostly used for AFP services
  1. Your Raspberry Pi will need a TashTalk hat or something similar. You can then run TashRouter (to route from LocalTalk to EtherTalk) and Netatalk (to share files/printers) on the Pi.
  2. Same deal as 1 except you don't need a TashTalk hat and TashRouter will be bridging from LToUDP (instead of LocalTalk) to EtherTalk.
  3. Same deal as 2 except you'd be running TashRouter and Netatalk on the Mac Mini. I'm not 100% positive TashRouter will be able to connect to EtherTalk on Mac OS, but it might? Depends on how tap interfaces work on Mac OS.
  4. Same deal as 1 except TashRouter will route between LocalTalk, EtherTalk, and LToUDP - simple change in configuration.
  5. Same deal as 3. It's AirTalk that's doing the bridging between LocalTalk and LToUDP, so even without TashRouter, you'd be able to connect Mini vMac on your Mac Mini to the PB 1400c.
Netatalk is indeed primarily an AFP server, but it comes bundled with the atalkd daemon that does AppleTalk routing, name registration, zone lookup, AEP (aecho) pings, etc. And then papd / pap / papstatus that handles everything PAP printing. Just sayin'
At any rate, it's great to see a fresh new userland AppleTalk project! I'm rooting for you @Bolacore
And yes, after spending 4 years of my life poking around in it, I can confirm that the Netatalk C API can be infuriating. ^^;
Yet, I still don't understand. Assuming I install Netatalk on my Raspberry PI3, what's the use-cases? Connecting up my PB1400c via ethernet to the PI3's ethernet? Then they can both chat on AppleTalk? Or, e.g. all the ethernet devices etc I can see on the PI3 are visible on the PB1400c? Or, e.g. I write a 'C' application that uses the Netatalk API on my PI3 and a corresponding 'C' app that interfaces to normal AppleTalk on the PB1400, and they chat with the same application-level protocol?
For me, it's having a single file server that can host files for all my Macs. Theoretically, it could also proxy print to my laser printer, but I always just print to PDF (or pict) on my Macs and send to a modern one for printing anyway, so the PAP printing is just a "yes, I could do that if I wanted to" for me.
In AppleTalk you register services (file services, print services, time services) with NBP and create routing tables with RTMP, for instance, which is part of what atalkd does and what this project will do as well. This is required to make a modern computer part of an AppleTalk network.
A high level overview in the netatalk developer docs: https://netatalk.io/developer/md_developer_2ddp
A simple architecture diagram that illustrates how the protocols link together: https://netatalk.io/developer/
The main difference in this project is that DDP will be in userland rather than in the kernel.
DDP in userland definitely seems like the future -- but aren't there going to be issues as time marches on with creating packets that leverage raw sockets from userland? Are there new APIs to handle creating and passing custom packets in userland? It's been over a decade since I've last delved into this. Seems to me that there's less userland functionality for raw sockets in macOS and Windows than there used to be.
This is what libpcap is for.
I can’t speak for Windows as I never really use it, and there’s virtually no chance it would disappear on Linux. For macOS I’d be surprised if they did - I’d be using the BPF interface there and removing it would break a heap of software like corporate VPNs that need it. I could see them gating it at one point maybe, but if VPNs still work there’d still be a way for us too.
The more I have messed with a homebrew AFP implementation the more I've come to realise just how brittle classic Mac OS really is
🫠 I have made my poor PowerBook crash so many times from malformed packets.
I'm currently trying to decipher what might be going on with the initial sign on and volume querying. The PowerBook is running 8.6, and discovers my server just fine, gets the server params, opens the volume, queries the access rights and offspring count of the root dir, and then after that it appears to query for "PHOTO_CD" in the root. If I respond with -5012 (ObjectNotFound) it seems to make my PB hard lock never to recover. No more packets, and it just drops me back to the Chooser screen as if things are OK, but nothing ever responds again.
If I pretend that it exists, it seems happier and starts trying to open data forks for info.pcd and also gets similarly cross if I respond that those dont exist.
Anyone more familiar with AFP might know what it is doing here? I dont know why it really wants this folder to exist. Here's the Wireshark excerpt, and attached the pcap as well. Will keep fiddling with it tomorrow.Screenshot From 2026-02-10 21-07-56.png
Ah good catch, I thought Wireshark was just being quirky there. Unfortunately even after fixing that error code it still exhibits the same behaviour - I see it execute the ATP release for my AFP response and then just stops responding. I'm tempted to try a clean install on this machine as I cannot find anything about PHOTO_CD being something Mac OS tries to find by default, maybe some odd extension trying to work.
Do you have the Kodak Photo CD extension loaded perchance?
