StyleWriterII Paper Feed Fix
Snial
Moderator
Staff member
68000
Hi folks,
I met up with a friend whom I haven't seen in decades, at the Everything Electric Show* in Farnborough and he gave me a number of StyleWriters in various states of disrepair! There's a 2x SWIIs, an SW1200 and a Color SW2400. One of the SWIIs (a yellowing one) doesn't seem to power up (no LEDs), but the other SWII and SW1200 do. Unfortunately they won't normally feed paper through, so it's impossible to do even a test image!
I found I could coerce the paper into the feed at which point it tried to do a test image, using an old, dry Apple ink cartridge. So, that was encouraging. I read that the rollers could wear out and I had seen some 'O' ring type things that had gone brittle and broken; so I took it apart and tried to fix it using some small rubber bands. Lo-and-behold, it could then feed paper through and when I swapped in a 35 year old Canon BC-02 (serial 9300E15, so maybe 1993?) it actually did do a test image print! How cool is that??!?!?
The next thing is to reassemble the little critter and see if the same trick will work with the SW1200!
I'm using the Repair Manual to do this, so there's less chance I'll snap some plastic lugs. I love the design though, basically it entirely clips together!
If it all works I'll hook it up to my PB1400 (or LC II). Originally I did have an SWII that I bought with my LCII (actually a P400) and thought it was great, mostly because it was simple, small and minimalist with crisp output.
* https://uk.everythingelectric.show/south
My first printer was a StyleWriter II. I still vividly remember the sound it made doing the test print (which as I recall they used as the sound effect of a fax machine in Lost In Translation)
My second printer was a StyleWriter II (my first being an ImageWriter II). I remember getting frustrated with the rollers; they wore down and lost their grip in an annoyingly short amount of time. I seem to recall replacing them with some hand-carved rubber at one point. But other than that, they still stand up to me as one of Canon's best maintainable inkjet printer designs.
The rubber band approach kinda worked to begin with, but then failed. At best it only worked when multiple sheets were in the feeder. However, I (or the chap who gave me the StyleWriters) had the idea of using finger sections from Marigold™ gloves.
I finally managed to test it today and so far it works flawlessly ( @adespoton ) , with multiple sheets and single sheets.
I need to put it back together now and do the same thing to the SW II that I had managed to get working. You can my B&W G3 on the bottom RHS, still awaiting a SATA flash reprogram!
Next update: That SW II also works with the fix! So I can sell at least one of them!
So, I've worked out that the second SW2's PSU is faulty, because when I wire up the first SW2's PSU to the second's logic board, the second SW2 powers on. Here's the good one (full size, sorry for any slow download):
And here's the faulty one (again, sorry for any slow download):
It's not the main fuse, which is a small 2A thing on the right, I've buzzed that out OK. Can you see any potential issues here? I'm planning to take the PSUs off both and check resistances for the components starting with what I think are two other fuses (the black rectangles on the left of the white SW 8.20 K thing (resistor?). And no, I won't be plugging it in at the time!
Finally, here's the image of the faulty one again. Except... this was one uploaded to my Mac mini 2012 (Catalina) as an HEIC viewed by Preview. Yes, there are HEIC decoding errors! I had to email it to myself as a jpg to view it properly.
Wild guess: Caps on the ouput side are probably sus.
There don't really seem to be many components on these, i guess you could try tweaking the adjustable voltage potentiometer to see if it helps with the voltages.
I wonder if these supply ordinary outputs without load or not, might be worth trying to see if you can measure any of the voltages.
Wild guess: Caps on the output side are probably sus.
Pretty good. I removed the PCBs from both. You can see that on the faulty one there's a lot of discolouration on the output side.
In fact it's possible to see an indication of the issue on the front from the earlier pictures, because D6 is corroded on the faulty one:
So, now I think I know what I might need to fix at the very least. 5 caps, 1 or 2 diodes, 1 or 2 inductors. All fairly common I think.
Hi Josh. I removed the components from the output side, i.e. the end that looks all blotchy. However, they all seem to function as I'd expect based on my multimeter. Caps charge up via the multimeter & I can see that in realtime - they're not shorted. The inductors do the opposite and even the big diode I thought was melted worked as a diode (though I didn't test any breakdown voltage I just used the diode setting on the multimeter).
I'm now looking further back through the board. I can see discolouration on earlier sections on the tracks. Not even sure what that is. Can't yet see any corroded components there. Any ideas anyone? Is this a normal PSU failure mode for a StyleWriter?
In PSUs generally, things I've seen include, sometimes the little DIP chip fails, or the output side capacitors go badly out of spec. Diodes fail on the input side... Sometimes fuses or resistors that act as a fuse near the mains input, but that tends to be a clue that something else failed.
Based on the condition of the board, it looks like the capacitors have probably leaked, even if they're still showing some capacitance, remember that you're measuring any other capacitors in parallel unless you remove them. I'd start by removing the caps one at a time and writing down what they are, cleaning the board and then putting back new caps. If you have a cheap cap tester you can test them individually out of circuit and most of the time it will let you spot which ones are completely toast. Just measuring the voltage charging isn't enough.
Sorry, I haven't read the thread, so all this is probably covered.
Last bit first. Bits have been covered, but not in the detail you say.
Oooh! Don't know how to test that.
I tested the main fuse, which was OK. The discolouration seems to start a bit after the first section.
OK, I don't have a capacitor tester. Naïvely I thought an ordinary Multimeter would do. I guess I should get one?
I guess though that if a cap leaked, but the board doesn't look like anything fried that's a positive thing. So far I'm glad you haven't pointed at the transformer or the odd white, copper wound doobrie. The transformer would take a lot of work for me to desolder.
So, in short - thanks for the help, it points me in the right direction!
