System 7 - Extension that shows internet connection status
The Internet doesn't really have a concept of "being connected to the Internet" -- you can check route and quality of connection to host, and with some specialized code and hardware can query BGP tables and do large volumes of traceroutes to map existing connectivity, but that's all going to change from moment to moment.
Yes, quite. I wrangle BGP for a relatively large chunk of the DFZ for a living. It's interesting. :-D
It sounds like a highly technical, but rather obscure and unknown corner of the Internet infrastructure, without which the entirety of the Internet might break.
Obscure and unknown but, yeah. I will not say who I work for - though it is trivial to find out - but I worked out today that probably every single day my code steers at least one tcp connection from every single person I have ever known or met, the ones I have forgotten and the ones who have forgotten me alike. I cannot tell you how weird that feeling is.
Unless they've gone completely off-grid of course. Or are dead, which is the offest of all grids.
I know it's not exactly what you asked for but sometimes you have to use what is available. So I have used Network Time Control Panel for this. In the settings you can have is get the time from time.apple.com and set it to check on boot and then every minute or so. If it cannot update the time it will give you an error. Simple and effective.
I was thinking the same thing, also this is also a good app to get around the Y2020 bug
