System 7 - Extension that shows internet connection status
I’ve been wondering for a while if such an extension for system 7 exists - one that allows you to see if there’s an active connection (through Ethernet cable, WiFi, etc) by displaying on the menu bar something like a blinking icon, or two different images depending on the status. Something similar in concept to the “Eyeballs” extension. I’ve done some research through the usual websites but I didn’t find anything that matches exactly what I’m looking for. In my case, I have an SE/30 with System 7.5.5 and a CNet PDS Ethernet card and a cable that goes straight to my router, so no WiFi cards or RPi in the middle.
I also wonder, in case nothing like it exists, how difficult would it be to create one from scratch?
I remember years ago there was a hard drive activity extension that basically did the same thing.
It would show drive read / write activity through a little icon in the menu bar.
If no one chimes in with a ready-made option, I might take a stab at this... although it's probably over my head. lol
Would you want just to see an 'link' indicator for the status? I think a 'every packet blink' would be pretty intense and distracting.
Aaron/DW
Dark Systems BBS
There are plenty of PPP/(C)SLIP monitor control panels or extensions (you can find these on info-mac mirrors). For wired LAN connectivity there’s not really "online" or "offline", as with PPP. There’s "cable plugged in and link established", but I’ve never seen software for Mac OS for this.
When you want to know whether your computer "can do Internet" it’s quite complex - having a non-APIPA-IP-address, having a gateway, being able to reach the gateway and beyond, having a name resolver, reaching that one. And even if the computer can reach the gateway -- this can be different 5, 10, 60 seconds later -- so your Mac would need to monitor that.
I’m writing to much text to explain that this is not really something for a 8 or 16 MHz machine -- that’s quite a bit of stuff to monitor. And Mac OS and MacTCP are known to react non-cooperatively/nice to timeouts.
What exactly do you want to know from that extension? If you plug in your Mac via LAN cable to your gateway, and it’s configured correctly, your Mac should be online.
Yes exactly, although as you say it could be a bit distracting if it blinked too often.
You are absolutely right and I probably didn’t realize that - maybe because I spent so much time and effort to succeed in connecting it to internet that I wanted to make sure it was connected 😂
But I still wondered if it’s doable and I realize now it’s not so easy.
AppleTalk already does this for network drive access, with the little double arrow near the apple menu, presumably you want that but for all network access?
All of this is good sense.
"Am I connected to the Internet" is a far more complicated question than it sounds, and "the Internet" isn't really a thing that exists anyway (he said, annoyingly). And MacTCP's API design makes it worse, I'm afraid.
Depending on what the OP wants, you could avoid the complexity and do something basic like have the extension attempt to ping a well known “Internet” service (e.g. Google’s DNS at 8.8.8.8) and just infer general public Internet connectivity if you can reach it.
I know it's not exactly what you asked for but sometimes you have to use what is available. So I have used Network Time Control Panel for this. In the settings you can have is get the time from time.apple.com and set it to check on boot and then every minute or so. If it cannot update the time it will give you an error. Simple and effective.
All your answers are actually quite interesting, I didn’t realize it was so complicated. I find it fascinating!
If this is possible then it would be more than enough. How complicated would it be to build as extension?
Good idea! I like it! I can try this too.
Given MacTCP's foibles, you would probably be better off doing it as a background application ('appe') if you don't mind being restricted to system 7. Then it wouldn't be too hard, although I'm not sure how reliable the MacTCP ICMP API is
Also very interesting! Guess I’ll have to start reading about programming apps 😃😃
All (MacTCP) Ping applications that I know hang (for a while) if there’s an error besides the target isn’t answering. Is this just sloppy programming, or is MacTCP’s routines hanging here in time-outs? If so, such an extension could make things worse :)
Yeah, I don't know. The theory is that you can do it like any other asynchronous I/O operation, by providing a completion procedure. That's easy to get wrong, so it might be sloppy programming. But as we are all in this thread well aware, MacTCP's software quality ain't exactly stellar, and it's totally possible there's something inside MacTCP that is having a funny five minutes at non-timeout ICMP response codes.
So it seems like a reasonable first step would be to build a non-crappy ping program that doesn't freeze for non-timeout ICMP errors - what do you think, @rieSha. ?
If you're using OT, the async I/O tends to work; there's just a split-second lock-up IIRC. With MacTCP, I seem to recall some block on buff stuff going on, where you need to fill/purge the input buffer to pass control back to the system. Not so much sloppy programming as all that could be done under the pre-system-7 architecture. OT gets around that by some fancy message passing so it doesn't have to loop while waiting for the buffer to fill up.
Of course, this is all from memory; I haven't touched any of that in (checks clock) around 30 years. The programming reference is a much better authority on this :)
That would provide some clarity for a proof-of-concept, absolutely.
To be honest, I doubt that it’s really worth it beyond gaining some knowledge, the path towards the goal would be the goal for me, because the tool the OP asked for is either incredibly inprecise, or super narrow focussed, or not working at all. I learned this bitter lesson when a colleague, an excellent network sysadmin, painstakenly walked me through his questionnaire “what do you precisely mean by asking »are we monitoring whether the company’s internet access is online/available«”
tl;dr: Perhaps one can craft a tool that displays “this box can ping a-b-c-d and it worked out >99% over the last minute”. But what is this good for, especially on a low power machine as a Mac SE or SE/30. IMHO: Let some other box do this heavy lifting. This is not shaming the Mac, hey, in the early ARPANET days even mainframe computers got an IMP (a "gateway" and "protocol converter" in today’s speak) in front of ’em, not attaching the expensive gear to the ARPANET directly. That IMP did the heavy (network) lifting. Therefor I rule it’s fine to have some BSD or Linux box doing the same with old Macs.
Sorry, lots of words, one more time: TL;DR: Use some BSD/Linux box (SBC or thin client) to monitor your home network, not a 68k-Mac.
YMMV.
oh, absolutely. I'm a network person, and the main reason to do this would be to explore how ill-defined a concept 'being connected to the Internet' actually is...
The Internet doesn't really have a concept of "being connected to the Internet" -- you can check route and quality of connection to host, and with some specialized code and hardware can query BGP tables and do large volumes of traceroutes to map existing connectivity, but that's all going to change from moment to moment.
I mean, I even have difficulty keeping it clear in my technically inclined family's heads that "functional NIC/Wifi", "connected to the LAN by NIC/Wifi" and "connected to the Internet gateway" are very different things. "Is the Internet up?" tends to be synonymous with all three for them, even if they're just trying to grab a file off the NAS.
