The CD-ROM door on this machine started sticking and not wanting to open. Anyone have that happen? Wondering if the tray is just hanging up on the facia.
Yeah, in messing with it, it just seems that somehow the tray is not matching up with the hole. Will see how I can adjust it when I can open things up.
You might have this sorted already, but it is either broken plastics or (more likely) it is just inserted wrong into the attachment guide (plastic frame, under the CD), You should be able to just push gently upward on the middle tab that is protruding slightly under the CD and pull the CD assembly out (not too much because the cables will still be connected in the rear of the CD). Then check the plastics and if nothing is broken, just align it correctly (so it is horizontal, instead of at an angle) and re-insert the CD.
