Power Mac G4 MDD FW800 power issues
mac27
I'm troubleshooting a FW800 MDD (Dual 1.25 GHz) with some weird behavior and am in need of some help on this one.
Description of the problem: The machine turns on / powers up; fans spin; HDDs spin up but then slowly spin down to a very low RPM (abnormal behavior). There is no boot chime and no video. The power LED glows briefly when first depressed, but does not turn back on and stay on like it's supposed to. There are no warning chimes.
Things I've tried so far:
- My first thought was RAM issues - have tried many different configurations, at least 3 different known-good sticks, and also no RAM at all. No change in behavior. Also no warning chimes when no RAM is installed, which is odd.
- Resetting PRAM (No response to this - same behavior).
- Removing all non-essential PCI cards, AirPort card, HDDs.
- Replacing speaker with known-good unit.
- Re-seating graphics card.
- Re-seating main power connector on the logic board.
- Re-seating CPU daughterboard and heat sink. (Inspected CPUs; they look normal).
- Application of new thermal paste.
- Installation (and removal) of PRAM battery.
Your first thought might be ... dead/failing PSU! That's what I thought also, so I've already sent it off to the MDD PSU repair service (ACX Electronics, Austin, TX). They replaced several of the usual-suspect caps and reported the PSU should be working normally. I also measured the voltages and they are normal. So I am wondering if this is actually something wrong with the motherboard or the CPU daughterboard. I do not have replacements for either on hand.
I've found some similar threads around, such as this one, but they're either not quite a match (e.g., slightly different symptoms), for a different model like the AGP, or they fixed theirs by doing things I've already done.
So ... I am at a loss on this one.. Any suggestions would be really appreciated. 🙏🏼
Did it work before, or are you trying to diagnose a new machine? Could it be booting, but without graphics? Is there HDD activity? Does the USB power up (...does a USB mouse light up)?
Seems like you’ve tried almost everything except… PMU reset?
Just tried that as well (twice, about 5-10 minutes apart with power-on in between), no dice unfortunately.
Interestingly, there is a section in the service source manual that describes this exact set of symptoms:
I've done the PMU reset, re-seated the cards, and I also reseated the processor daughterboard as well just now. *sigh* I have a feeling I'm gonna be looking at a new daughterboard, at least.
This machine was working normally until this problem randomly appeared one day. I hadn't done anything to it whatsoever. One day it was working fine, the next I went to power it up and this was happening.
I think if it were booting I'd get a chime at least, the fact that there isn't even a warning "beep" with no RAM installed is concerning to me.
I haven't tried connecting peripherals directly to the tower (hasn't been much point yet), but there is no power to USB peripherals over ADC and no display. The ADC display's power LED does flash and fade out when you tap the power "button" while the tower is on, but that's it.
Pins might look normal to the naked eye — but no harm in carefully cleaning them anyway… as oxidation, corrosion, etc. can and does take place in these now 23 year old machines.
Another oddity is that CPU daughtercards warp… and applying slight, yet brief downward pressure (by hand) to the heatsink upon a cold boot, can reveal this possibility… if it does boot as it should with such pressure.
ALSO… test with no RAM in the J20 slot. Have seen a few of these lately, where the J20 slot seems to have expanded over time… and possibly in relation to the close proximity to the GPU.
Just a few things off the top of my head. But if you want to test with another motherboard I have quite a few available. (Yours for the cost of shipping alone perhaps.) DM me.
Thanks for these suggestions. I've tried many configurations of RAM, and just tried again with no stick in J20 to make sure. No change (and still no warning beeps with no RAM installed at all, which is odd).
I also tried various pressures on the heatsink manually during boot, no change with that either.
For cleaning the daughterboard connector and slot, would some contact cleaner on a toothbrush be the best way to go about this? I've not manually cleaned one of these processor daughterboard connections before and will need to be exceedingly careful.
Yes, I have carefully used a soft bristle toothbrush with both DeoxIT - D100L and then also 91% isopropyl alcohol. (One or the other and sometimes both.)
Thanks. So to update my list from above, I've now (in addition) also tried:
- Resetting PMU (3 or 4 times now in total)
- Re-seating CPU daughterboard and cleaning connections on both sides with Deoxit
- Applying pressure to heat sink in various fashions during power-on
@MBongo has very generously offered a suitable motherboard so replacing that will be the next step ... will update later.
The replacement motherboard arrived today; got it installed and that did the trick. Woohoo! My first time actually seeing it boot in several months, at least.
So, what can I say about this? - having a motherboard randomly fail with no warning signs is certainly a new one for me, and the collection. My first thought is caps? They look fine but that doesn't always tell the whole story. Or maybe some other minute little problem that's imperceptible to someone with my tools, equipment, and skillset.
Anyways, HUGE thanks to @MBongo for saving the day on this one. I can now also attest that the PSU recap service was a success and that 100% was not the issue.
OK so testing mine.
* Tested the power supply with a multimeter and scope, and the voltages look good with minimal peak to peak variantion. ADC power is there as well
* Mine didn't have a lithium battery installed, but I got a bunch delivered today and installed
* PMU reset done
* Only logic board powered + one stick of ram (it did have 4x512MB PC-3200U sticks in there)
* CPU card removed and cleaned
But alas, no go, from turning on a get:
Power LED flashes on, then off
Red LED on the logic board lights up
Fans run at normal speed
then about 20 secs the main CPU fan goes full speed
No startup chime, nothing on screen
I'm hoping there are some more troubleshooting steps I can do???
In no particular order, here…
All wires from PSU to mobo not scraped, shorted, exposed - especially around hinge area?
All cards removed except video card, its contacts all cleaned?
One stick of RAM tested in any other slot than J20?
All PSU connections to the mobo clean and good?
NO network card / connections, ethernet etc.?
Tried slight downward pressure on heatsink?
Tried booting from any installer CD?
PRAM zapped? Cmd+Opt+P+R
Tried Safe booting?
As fans begin normally at first, then CPU fan goes full speed… initially this suggests that maybe heatsink or CPU not seated properly as temp sensors quickly sense & signal need for more cooling? (Use an independent fan on the CPU / heatsink when open door testing?) Renew heatsink paste again, in case you’ve any voids in previous application.
Might check heatsink temperature rise from cold boot, against after when it shuts down? If you’ve no suitable temp probe for this, then palm of your hand can possibly help to gauge this.
No recent hardware or software changes and the machine performed well, previously?
This machine is from a haul from 15 years ago, along with g5s etc. The MDD is just so good looking a really want to get it going.
Ok, did a bit more testing but no luck. Have done all the checks above.
At this stage, I'm going re-pin an ATX power supply just to be 100% sure the power supply is not the issue (but I think the power supply is OK). Then I'm going to yank the board and inspect the caps around the CPU board carefully, and double check CPU board, etc.
At that stage, if I've ruled the power supply completely out, I might just park it or take a punt on a replacement logic board (hoping my CPU card is good).
My own experiences have led me to believe that the MDD G4 Macs have multiple time-related issues.
I have a 2003 dual 1.25GHz FW400 MDD G4 that was in daily use from 2004 to 2018, and a backup single 1.25GHz MDD G4. When the original became too unstable to use, I tried using the previously good backup, but it was just as unstable.
I tried using refurbished power supplies, an ATX power supply with ATX-G4 cable, different RAM sticks/CPUs/logic boards/VGA cards/cables/hard drives/SSDs/optical drives, and a recapped logic board. Both MDD G4’s remain unstable.
I will be watching this thread with interest.
Best of luck - if you do end up needing a replacement mobo, I might be able to help out.
Yeah that's a bummer. I wish I could be more specific on what exactly the issue is/was, other than "needed new motherboard". Maybe someday I'll give it to someone who can actually diagnose the original and figure out what happened.
Ok more testing, and power supply is definitely good I repinned a 525W dell power supply as it had a full 24pin connector on it, and same behaviour.
Power on, led flash, low fans, 20 secs in CPU fan full speed, no chime, nothing on screen.
At this point I really need some tips on isolating whether it the logic board or CPU daughter board as don't feel like doing a coin toss and ordering one to find out the fault.was.with the other.
Hi, here is an idea.. On the MDD's I remember these have front panel boards and if those go bad that could cause issues from the system not able to turn on, to acting as a dead machine. Look at your front panel board and if you can find another part, you can do a test. I don't remember the Apple part number for that however as its been a long time since I had to change mine.
Hello there !
Got a similar model, and I'm looking for help with similiar problem. But in my case, mine chimes and a few seconds latter it shuts down, no video and no other error. Is this a good thing it's is chiming ?
