Maximum SiliconExpress IV Throughput
eharmon
Continuing my SiliconExpress experimentation, I've been doing some benchmarks on my Quadra 650 board with ZuluSCSI.
Read
Native SCSIZuluSCSI (RP2040)4,700KB/s
SiliconExpress IV (8-bit) - 1.6.5ZuluSCSI (RP2040)8,123KB/s
SiliconExpress IV (16-bit) - 1.6.5ZuluSCSI Wide8,959KB/s
Write results are generally ~30% slower.
I need to try the SCSI 4.3 firmware to see if it's any different.
Wombat boards have a NuBus implementation that leaves a bit to be desired (no double data rate transfers @ 20MHz except between cards), which TIL 9305 implies should give you 8-10MB/s to the logic board and a theoretical 20MB/s out of the logic board (if the destination device could accept block transfers at zero wait). So that seems ballpark to what we're getting.
Still, surprisingly rough! So it seems on the earlier Quadras there's only a small boost from moving to 16-bit (~10%).
The official documentation always seemed ambiguous to me if later devices really supported 20MHz transfers to the logic board. Has anyone benchmarked a Quadra AV or 6100/7100/8100 and a SiliconExpress?
I benched spinning disks ages ago on Jackhammers and SEIV (I have SEII's and other Nubus SCSI cards as well). There should be results from back then on the forum if you search.
An interesting data point - unfortunately I didn't document much of it - I did exactly what you've done here a couple of years ago with a SCSI2SD v6. What stands out to me is that I got the same results as you through the SEIV, but my native reads were significantly slower than yours at ~2800
I do have an 840av now and still have the SEIV, but I have little spare time for this kind of thing right now...
Here are my old threads on the topic, someone else posted some Q950 and PM8100 benchmarks in the SEIV one:
Interesting, so from those benchmarks, you can't really break the 10MB/s barrier on an 8100 either. I also noticed the same dip with a PowerPC card in the Quadra.
The RP2040 Zulu is quite a bit faster than the SCSI2SD v6. I wonder if the card's read ahead cache makes up for lower transaction performance, which is why you see a bigger jump on the SCSI2SD.
I want to run three more benchmarks:
  • Run the Q650 @ 40MHz. It won't speed NuBus but it will tighten memory performance which might squeak a little more speed out. Doubt it makes much of a difference.
  • Switch to the SCSI 4.3 firmware. Theoretically this improves burst performance as we're less bottlenecked on the CPU. Again, I doubt it makes much of a difference, but maybe it brings back PPC perf.
  • Assign the card to a Radius Rocket, which should allow direct NuBus 90 transfers. The chip on the SE IV is definitely capable of 20MB/s, so if anything can do it, that should.
The earlier rockets don't support 20mhz transfers; the extra pins to support 2x transfers aren't wired. Rockets all support block transfers and can perform block transfers between cards (even if the host doesn't support block transfers) but it's at the standard 10mhz rate. Maybe the later Stage II Rockets support 2x. You might check the SCSI card too - if those pins aren't wired, then no 2x transfers.
Not in front of me right now, but I was able to get ~18MB/sec on a Quadra 840AV with a 10kRPM 16-bit drive attached to an SEIV. I think the 8100/100 and 8100/110 will perform within ballpark. The 6100, 7100, and 8100/80 have an older version of the NuBus controller IIRC which may inhibit performance.
Yeah, I'm gonna try a Stage II. The docs claim they're wired for 20MHz operation, but I'll take a look at the board!
Interesting. So maybe they really are faster, or maybe there's an interaction between the SE IV and a ZuluSCSI Blaster. There's a number of improvements in later machines that could definitely explain performance improvements, but it's rather ambiguous:
  • The Quadra AVs have a MUNI controller and the x100 a BART, which should be a an updated version, implying the x100's should be more capable but...you never know.
  • The Quadra AV Developer Note notes "faster data transfer rates to and from the CPU bus" and "NuBus '90 transfers between cards at a clock rate of 20MHz". The x100 Developer Note notes that BART supports "transferring one-cycle or four-cycle transactions".
  • I haven't found a copy of the 8100/110's Developer Note, but the 8100's spec sheet claims "Three internal NuBus expansion slots; the 8100/110 also supports higher-performance burst mode between NuBus cards". Calling it out implies something new, but it still ambiguously claims the performance boost is only "between cards".
  • For all these newer machines, there's quite a few DMA improvements as well which could reduce overhead.
It's pretty bizarre how poorly documented it is. While PCI was on the horizon, you'd think better NuBus would have been something worth marketing! I'm inclined to believe the AVs and x100 are faster (and maybe 8100/110 even more).
Very interesting! How much does the maximum throughput affect user perception? That is, how much does it shave off of boot time or launching an application?
I don't know enough about SCSI, but can you make a call asynchronously to one drive, and then to another drive, and when the results are ready from either drive it will ask for attention? Or is the bus reserved until the first drive returns its result?
