It is a long time since I've actually used a _working_ Mac Classic (I'm a Plus/SE guy), but I'm trying to see if I can get one of mine operational. This one has no visible electrolyte leakage, solder joints look good, and the battery was deleted long before it could cause any problems. Very clean machine internally.
Can someone remind me what the expected behavior is when I plug in the power and turn on the physical power switch? My recollection is that it should start the fan (only), and that the HDD should spin up only at the same time as I hear the chime, when I press the power button on an attached ADB keyboard.
Right now this unit is spinning up both the fan and HDD as soon as I turn on the power switch. I see the CRT heater glowing also, but don't hear the h-sync (might just be my old ears, I can only JUST hear NTSC and the Classic is higher frequency
). Nothing happens when I press the power button on the keyboard. I've also tried pressing Cmd-Opt-PR immediately after the power button, and nothing happens there either even if I wait for a minute.
Haven't scoped the power lines for noise yet. Don't really want to recap this machine but if it's what I gotta do it's what I gotta do... but it really does look pristine inside. Sigh. Time to dig out the ol'd SMD electro kit I guess.
