Picked up an untested SE that turns on but no bong or display output.
I can hear CRT initialize
Power supply is giving out correct voltages
RAM and CPU get slightly warm when left on
no capacitor or battery leakage on motherboard
Tried:
maxing display brightness
external speaker for startup tone, still nothing
reflowing solder joints on analog board
activating diagnostic mode by holding interupt button with serial port connected, no output. Also couldnt find a ton of docs on this for the non /30 so could be doing it wrong.
Known good ram
cleaned motherboard to remove grime and look for bad traces, didn't see anything out of ordinary.
Anyone have any other ideas? Unfortunately the only other compact I have is my Plus so not much to swap between them.
Tried:
Known good ram
