Hi everyone,
I’ve been quietly tinkering with a project and wanted to see if there’s interest in a small-run kit.
Quick background: my fiancée and I run the PC-hardware YouTube channel “tektherapy,” and I previously operated a console-mod shop focused on BGA rework/soldering. In short, I have solid access to parts and fabrication—which helps here.
The project: adapting a 120 mm PC AIO liquid cooler for the Power Mac G4 MDD. My test unit is a dual 1.25 GHz overclocked to 1.5 GHz. I’ve mounted a 120 mm radiator in front of a new, quieter left-side exhaust fan near the HDD tray. Even at low fan RPM, peak CPU temps drop noticeably, and the loop keeps temps from spiking quickly under load.
Next steps (hardware I’m designing):
Related ideas (for later): I’ve already swapped the PSU fans for Noctuas, which helped. I’m also considering an SFX-PSU mounting bracket to run modern SFX-PSUs with ATX cable adapters—ideally without losing ADC. (Working on a curcuitry for this)
Proposal: if there’s interest, I can produce a kit that includes a compatible 120 mm AIO plus laser-cut metal mounting brackets (current prototypes are 3D-printed; production would be metal for stability).
Would this be useful to folks here?
I’ll add photos to this thread soon—I’m traveling at the moment and finally had a chance to post.
For the admins: this isn’t self-promotion; I’m gauging interest in a community-useful solution.
- Clean radiator clamps/brackets for a proper MDD fit
- A CPU bracket/adapter to mount the AIO pump with minimal fuss
