Hello hivemind!
I'm working on getting a M1212 monitor fixed up - seems to work well except that the flyback transformer makes a god awful screech. I want so badly to use it with my Quadra 605 but I can't stand being in the same room...
I've tried coating parts of the flyback in RTV to dampen the vibrations, and tried strategically wedging toothpicks against it to try and couple the vibration to other parts, both without success. I might have even made it worse!
I've got an LC575 analog board in the parts bin that worked well when it was pulled. Could I stick the flyback from the LC575 onto my M1212?
Flyback part numbers are different, but the 2 monitors use the same CRT, same resolution, same video timings, probably same anode voltage?
